ezloPi Addressable LED Chase Blackout Rainbow effect with reverse function
Chase Blackout Rainbow effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Chase Blackout Rainbow” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi Addressable LED Chase Blackout Rainbow effect with reverse function, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
| Addressable LED strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
1. First setup your MiOS account by visiting ezlopi.com - Setup MiOS Account and set up your device/hardware by visiting config.ezlopi.com
- A window will appear on the bottom left side of the screen displaying "Please press BOOT button while flashing begins."
- Hold the BOOT button down until the next window appears on the bottom left side of the screen which says "Installation prepared. Please release the boot button now."
5. MiOS Web Dashboard:
- A new window will open where you can control your RGB LED.
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it to 10. Now, add another segment by clicking the Add segment option because we want to show effects on two different segments of LEDs. Again we set the number of LEDs for the effect we want to set for Segment 1. We click on the Reverse direction option for this because we want to apply the same effect to both segments but we have reversed the direction of applied effect in Segment 1.
- Under Effect mode, click on Chase Blackout Rainbow to apply this effect. By following the above steps, we can successfully implement a Chase Blackout Rainbow effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
