ezloPi Addressable LED Chase Blackout Rainbow Effect
Chase Blackout Rainbow effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Chase Blackout Rainbow” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi Addressable LED Chase Blackout Rainbow Effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
| Addressable LED strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
5. MiOS Web Dashboard
- A new window will open where you can control your RGB LED.
- Under Effect mode, click on Chase Blackout Rainbow to apply this effect. By following the above steps, we can successfully implement a bicolor chase effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
