ezloPi addressable LED Blink effect
Blink effect (ON and OFF after some delay) implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Blink” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ezloPi addressable LED Blink effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Connect your RGB LED(whether 5V or 12V) strip’s data pin (Din) to RX2 pin (GPIO16) on ESP32 board
| Addressable LED strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
Click Connect.
5. MiOS Web Dashboard
- After configuring the controller with the EzloPi web flasher, head to https://ezlogic.mios.com
- A new window will open where you can control your RGB LED.
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to set for specific effect. In our case, we have set it from 0 to 10 which are the 10 LEDs as shown in the pic. Here, we can also set the reverse direction of LEDs which will apply the effect in reverse (from last LED to first).
- Under Effect mode, click on Blink to apply this effect. By following the above steps, we can successfully implement a blink effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
