ESP32 WEMOS D1 R32 and IR Proximity Sensor (Replace Arduino with ESP-based board)
Transform motion into smart innovation using EzloPi
Motion detection by interfacing IR proximity sensor (Replace Arduino with ESP-based board)
In this project demonstration, we will show you how to convert an existing project which uses an Arduino board and a proximity sensor into a smart project using the ESP32-based development board. The ESP-based EzloPi device provides the capabilities to convert your hardware (projects or devices/sensors) into IoT capable devices.
This following user guide will take you through the steps to make a smart project using ESP MCU based boards. We can get an understanding for this easy process by interfacing the IR proximity sensor project.
Welcome to the project demonstration video section. The following video showcases the key aspects of ESP32 WEMOS D1 R32 and IR Proximity Sensor (Replace Arduino with ESP-based board), providing a visual walkthrough of its implementation.
  • ESP32 WEMOS D1 R32 as an EzloPi smart device.
  • FC-51 Infrared (IR) Proximity Sensor.
The wiring diagram for ESP32 WEMOS D1 R32 is represented as follows:
From ESP32 WEMOS D1 R32 to IR Proximity Sensor:
  • Connect 3V3 from the ESP32 WEMOS D1 R32 to the VCC of the sensor.
  • Connect GND from the ESP32 WEMOS D1 R32 to the GND pin of the sensor.
  • Connect IO4 from the ESP32 WEMOS D1 R32 to the OUT pin of the sensor.
4. Configurations steps to make ESPduino (ESP32 WEMOS D1 R32) into a EzloPi smart device:
Interfacing the Proximity Sensor using the EzloPi Web Flasher
Click Connect.
  2. In the Device Configuration, tab click on Digital Input.
  1. A Digital Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to Proximity Sensor.
  • Set the Input GPIO to 4.
  • Set Device Subtype to Proximity Sensor.
  • Set the Resistor to PULL DOWN.
  • Now Click the Apply button.
5. MiOS App
Google PlayApple App Store
  1. After opening the dashboard, you will be able to see the tile of your connected device.
  2. Here, as you can see in the MiOS mobile app dashboard, we can see the proximity sensor tile which lights up when any motion is detected by the sensor.
  3. Here, it can be seen that we have successfully converted an Arduino project into a smart project by using an ESP-based development board.
6. MiOS Web Application
  1. Now, on the MiOS web dashboard, you will be able to see the tile for the proximity sensor which indicates if any motion or an object is being detected by the sensor.
  1. Here, it can be seen that we have successfully converted an Arduino project into a smart project by using an ESP-based development board. The bulb indicates that the motion or object is being detected by the sensor as shown on the MiOS app.
Buy Components
