Enhancing parking detection using proximity sensor and neon light
The project aims to integrate an FC-51 proximity sensor with an EzloPi device to facilitate parking detection. The FC-51 sensor will be employed to detect the distance between the car and the wall, ensuring safe parking. When the car approaches a predetermined safe distance, a neon light connected to the EzloPi device will be triggered to provide a visual alert to the driver. This integration involves interpreting the sensor's data and activating the neon light accordingly. This solution offers a user-friendly and effective means of enhancing parking safety by providing real-time visual feedback to drivers. Additionally, the project will emphasize ease of installation and reliability for seamless into a smart home environment.
Welcome to the project demonstration video section. The following video showcases the key aspects of Get notified when fan gets powered ON, providing a visual walkthrough of its implementation.
- ESP32 as an EzloPi smart device
- FC-51 Proximity sensor
- XY-MOS, high-power dual MOSFET driver module
- Flexible neon LED strip
- 12V power source
From ESP32 to the FC-51 Proximity sensor:
| ESP32 | FCP-51 Proximity Sensor |
| 3V3 | VCC |
| GND | GND |
| D4 | OUT |
From MOSFET driver module to LED Strip:
| MOSFET Driver | LED Strip |
| OUT+ | 5V |
| OUT- | GND |
From 12V Power supply to MOSFET driver module:
| 12V Power supply | MOSFET driver |
| VCC | VIN+ |
| GND | VIN- |
4. Interfacing the Neon Light with Proximity sensor using the EzloPi Web Flasher
Click Connect
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Proximity Sensor.
- Set OUT GPIO to 4.
- Set Device Subtype to IR Proximity Sensor.
- Set default value to LOW.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Output.
- Set a device name of your choosing. In our case, we set it to Neon Light.
- Set Device Subtype to LED.
- Set OUT GPIO to 5.
- Set Resistor to PULL UP.
- Then click Apply Button.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will be able to see the tile for proximity sensor and Neon light. These tiles show the status of proximity sensor and the neon light.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Proximity with Neon Light.
- Set Node Type to Device.
- Set the Node to Proximity Sensor.
- Set the Capability to Motion.
- Set the Value to True.
- Set these values in the True part of the ACTION section.
- Set the Controllable to Neon Light.
- Set the Capability to switch.
- Set the Value to true.
- Set these values in the False part of the ACTION section.
- Set the Value to false.
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device, in our case the proximity sensor and neon light.
- While parking, whenever the car is away from the proximity sensor, it will not detect any motion or trigger the neon light, For now no motion is being detected.
- Similarly, it can be seen that when the car comes close to the proximity sensor, it detects motion and the neon light gets triggered. This is because of the meshbot rules we have set earlier.
6. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device, in our case the proximity sensor and neon light.
