![Enhanced Vibration detection using vibration sensor & PIR sensor](https://pi.ezlo.com/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor.webp)
Feel the vibrations with EzloPi!
This project aims to enhance vibration detection capabilities by interfacing the SW180P vibration sensor module and PIR motion sensor module with the EzloPi device. The SW180P sensor detects vibrations, while the PIR sensor identifies motion, providing a dual-sensor system for improved accuracy in detecting physical disturbances. The EzloPi device serves as the central controller, integrating sensor data and enabling communication. This setup can be used in security systems, where precise detection of both vibrations and motion is crucial.
Welcome to the project demonstration video section. The following video showcases the key aspects of Enhanced Vibration detection using vibration sensor & PIR sensor, providing a visual walkthrough of its implementation.
- SW180P vibration sensor module.
- PIR motion sensor module.
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-wiring-diagram.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-circuit-setup.webp)
From ESP32 to the Vibration Sensor Module:
ESP32 | Vibration Sensor |
3V3 | VCC |
GND | GND |
D2 | D0 |
From ESP32 to the PIR Motion Sensor:
ESP32 | PIR Motion Sensor |
3V3 | VCC |
GND | GND |
D21 | OUT |
4. Interfacing the Vibration sensor module & PIR Sensor with EzloPi Web Flasher
![](/wp-content/uploads/2024/03/ezlopi-addressable-led-blink-effect-1.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-1.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-2.webp)
Click Connect
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-3.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-4.webp)
- An Digital Input window will open for inputting the following parameters:
- Set a Device Name of your choosing. In our case we set it to PIR Sensor.
- Set Digital input pin to 21.
- Set Device Subtype to PIR Sensor.
- Set Default Value to LOW.
- Now, Click the Apply button.
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-5.webp)
- Set a Device Name of your choosing. In our case, we set it to Vibration Sensor.
- Set Digital input pin to 2.
- Set Device Subtype to Vibration Sensor.
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-6.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-7.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-8.webp)
5. MiOS App
![](/wp-content/uploads/2023/12/humidity-alert-with-ezlopi-meshbot-email-notification-20.webp)
![](/wp-content/uploads/2023/12/humidity-alert-with-ezlopi-meshbot-email-notification-21.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-9.webp)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-10.webp)
- After opening the MiOS mobile dashboard, you can see the tiles of your connected devices labeled as PIR sensor and vibration sensor respectively. Both are showing “No motion” on their respective tiles.
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-11.webp)
- Now, we can see that when PIR and Vibration sensors are triggered by some motion or vibrations, The tiles are enabled and show “Motion” messages.
6. MiOS Web Dashboard
![](/wp-content/uploads/2024/01/combustible-gas-detection-using-mq-9-gas-sensor-EzloPi-web-flasher.png)
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-12.webp)
- In the MIOS Web dashboard, you can see the tiles of your connected devices labeled as PIR sensor and Vibration sensor respectively, Both are showing “No motion” on their respective tiles.
MeshBots:
![](/wp-content/uploads/2024/06/enhanced-vibration-detection-using-vibration-sensor-pir-sensor-13.webp)
![](https://pi.ezlo.com/wp-content/uploads/2023/05/product-1.png)
![](https://pi.ezlo.com/wp-content/uploads/2023/05/product-2.png)
![](https://pi.ezlo.com/wp-content/uploads/2023/05/product-3.png)
![](https://pi.ezlo.com/wp-content/uploads/2023/05/product-4.png)
![](https://pi.ezlo.com/wp-content/uploads/2023/05/product-5.png)
