Automate your life with EzloPi!
Enhance safety using proximity sensor
This project involves interfacing an FC-51 proximity sensor with a DC motor using the EzloPi device to enhance safety measures. The FC-51 sensor will detect the presence of a person or object within a specified range. Upon detection, the EzloPi device will process the signal and activate the DC motor, which can be used to trigger a safety mechanism, such as stopping a machine or closing a barrier. This setup aims to prevent accidents and ensure a safer environment by automatically responding to the presence of individuals near potentially hazardous equipment. The integration leverages the ease of use and flexibility of the EzloPi device for efficient and reliable operation.
Welcome to the project demonstration video section. The following video showcases the key aspects of Enhance safety using proximity sensor, providing a visual walkthrough of its implementation.
- ESP32 as an EzloPi smart device
- FC-51 Proximity sensor
- Single channel relay shield
- DC Motor
- DC power source
From ESP32 to the FC-51 Proximity sensor:
| ESP32 | FC-51 Proximity sensor |
| 3V3 | VCC |
| GND | GND |
| D15 | OUT |
From ESP32 to the Single Channel Relay module:
| ESP32 | Relay Module |
| GND | + (VCC) |
| GND | - (GND) |
| D4 | S (Signal) |
From Relay Module to DC Motor & Power Supply:
| Relay Module | Power Supply |
| NO | Positive Terminal |
| NC | Negative Terminal & 2nd Terminal of Motor |
| COM | 1st Terminal of Motor |
4. Interfacing the DC Motor with Proximity sensor using the EzloPi Web Flasher
Click Connect
- A window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Proximity Sensor.
- Set OUT GPIO to 15.
- Set Device Subtype to IR Proximity Sensor.
- Set Resistor to PULL DOWN.
- Set default value to LOW.
- Now Click the Apply button.
- Set a Device name of your choosing. In our case, we set it to DC Motor.
- Set Device Subtype to Relay.
- Set OUT GPIO to 4.
- Set Resistor to PULL UP.
5. MiOS Web Dashboard
- On the MiOS web dashboard, you will be able to see the tiles for proximity sensor and motor. These tiles show the status of all the devices. For now, no device is triggered/turned on.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test002.
- Set Node Type to Device.
- Set the Node to Proximity Sensor.
- Set the Capability to Motion.
- Set the value to True.
- Set these values in the True part of the ACTION section.
- Set Controllable Type to DC Motor.
- Set the Capability to Switch.
- Set the value to false.
- Set these values in the False part of the ACTION section.
- Set the value to true.
- As we can see, our motor is running, when the proximity sensor detects the presence of a person or a pet, it gets triggered and our motor stops because of the rules we have set in the meshbot.
- As we can see, when our proximity sensor gets triggered by a person or pet as shown by the tile, the motor stops because of the rules we have set in the meshbot.
6. MiOS App
- On the MiOS mobile dashboard, you will be able to see the tiles for proximity sensor and motor. These tiles show the status of all the devices. For now, no device is triggered.
6. MiOS Web Application
- After opening the MiOS mobile app dashboard, We can see that when the Light is operated from the First Floor Button, The Light turns on because of the rule we have set in the meshbot.
- Now, We can see that when the Light is operated from the Ground Floor Button, The Light turns on because of the rule we have set in the meshbot.
