Soil Whispers: EzloPi and Soil Sensor Sharing Secrets in Your Email.
Email notification with soil moisture sensor
In this project, we seamlessly integrate a soil moisture sensor with the EzloPi Smart Device. We've created a system that provides real-time insights into the moisture levels of your soil. Receive prompt email notifications that keep you informed and in control, also monitor the moisture levels of the soil through the MiOS user-friendly interface, ensuring optimal conditions for your plants, wherever they may be. The EzloPi Smart Device becomes your intelligent assistant allowing integration of automated watering systems, offering timely updates and helping you create the perfect environment for your plants to thrive.
Welcome to the project demonstration video section. The following video showcases the key aspects of Send automatic email notification using soil moisture sensor on EzloPi Platform, providing a visual walkthrough of its implementation.
The following components are required for interfacing using the EzloPi device:
- ESP32 as EzloPi smart device.
- FC-28 Soil Moisture Sensor Module.
From ESP32 to the Soil Moisture Sensor Module:
- Connect the 3v3 pin from ESP32 to the VCC terminal on the moisture sensor module.
- Connect GND to the GND Pin.
- Connect D33 from the ESP to the signal (A0) pin.
From the Sensor Module to the FC-28:
- Connect the (+) from Soil Moisture Sensor Module to one side of FC-28
- Connect the (-) from Soil Moisture Sensor Module to the other side of FC-28
4. Interfacing the Soil Moisture Sensor with EzloPi Web Flasher
Click Connect.
- Set a device name of your choosing. In our case we set it to Soil Moisture Sensor.
- Set device Sub Type to Soil Moisture Sensor
- Set ADC input pin to 33.
- Set the Resolution to 10-bit
- Now Click the Apply button.
5. MiOS Web Application
- In the dashboard, you can also see the tile labeled as soil moisture sensor, which is showing 41% moisture level of the soil sample.
- Here as you can see in the example given above, we can see the soil moisture sensor tile. The tile shows the Soil moisture levels being detected by the sensor.
MeshBots
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set Node Type to Device.
- Set the Node to Soil Moisture Sensor.
- Set the Capability to Moisture.
- Set the variables to percentage.
- Set the Comparator to Greater (>).
- Set the value to 60(It will trigger when humidity is greater than 40).
- Set Controllable Type to Notification.
- Set the User to Your user account, in our case the user account is Tayyab.
- Set the Channels to email,push.
- Set the Subject to Soil Moisture Update.
- Set the Message body info to Soil Moisture has been increased.
- Here in the MiOS web dashboard, you can see the humidity is below 40%. In this scenario, email will not be sent to alert the user.
- Now, as you can see that Soil moisture has increased to 42% which is more than 40 %.
- In this scenario, an email is generated to the user’s gmail account which can be seen below.
5. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- Here, as you can see in the MiOS mobile app dashboard, the soil moisture sensor tile, which shows the moisture level as 40% of the soil sample on which the sensor was used.
- Similarly, as you can see in the MiOS mobile app dashboard, the soil moisture sensor tile, which shows the moisture level as 41% of the soil sample on which the sensor was used.
