Elderly fall detection system using shock sensor and alarm
The following system is designed to monitor falls and provide immediate alerts, ensuring timely assistance for seniors. It utilizes the KY-002 vibration tilt sensor module to detect sudden shocks or falls. When a fall is detected, the MH-FMD buzzer is triggered, generating a loud alarm to notify caregivers or family members. The EzloPi smart device acts as the central hub, processing the sensor's output and activating the alarm system. This system is compact and easy to integrate and ensures enhanced safety and quick response during emergencies, making it an ideal solution for elderly care.
  • KY-002 Vibration tilt sensor module.
  • MH-FMD buzzer
From ESP32 to the Shock Sensor Module:
ESP32KY-002
3V3VIN
GNDGND
D15S
From ESP32 to the Buzzer:
ESP32Buzzer
3V3VCC
GNDGND
D4I/O
4. Interfacing the Vibration Sensor Module with the EzloPi Web Flasher
Click Connect
  2. In the Device Configuration, tab click on Digital Input.
  1. A Digital Input window will be opened for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to KY-002 Shock Sensor.
  • Set INPUT GPIO pin to 15.
  • Set Device Subtype to Vibration Sensor.
  • Set Resistor to PULL UP.
  • Set Default Value to LOW.
  • Then Click Apply Button.
  1. Again, In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will be opened for inputting the following parameters.
  • Set a Device name of your choosing. In our case we set it to Buzzer Alarm.
  • Set Device Subtype to LED.
  • Set OUT GPIO pin to 4.
5. MiOS Web Dashboard
  1. On the MiOS web dashboard, you will see the tiles of your connected devices as shown above labeled as KY-002 Shock Sensor and Buzzer Alarm. Currently, no shock or vibration is detected by the sensor therefore the shock sensor shows “No Motion” message and buzzer alarm tile also shows the “Off” message.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to KY-002 Shock Sensor.
  • Set the Capability to Activity.
  • Set the value to drop.
  1. Set these values in the True part of the ACTION section.
  • Set Node type to Device.
  • Set Controllable to Buzzer Alarm.
  • Set Capability to switch.
  • Set value to true.
  1. Set these values in the False part of the ACTION section.
  • Set value to false.
  • After clicking the apply button you can see a table of your setting in the Current configuration tab.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now in the above pic, It shows that the shock sensor detects a shock or high vibrations, the buzzer alarm gets turned ON to alert the family members or caretaker that the elderly person has fallen because of the rules we have set in the meshbot.
6. MiOS App
Google PlayApple App Store
  1. Now, on the MiOS web app, you will see the tiles of your connected devices as shown above labeled as KY-002 Shock Sensor and Buzzer Alarm. Currently, no shock or vibration is detected by the sensor therefore the Shock sensor shows “No Motion” message and buzzer alarm tile also shows the “Off” message.
Buy Components
