Efficient gas monitoring
Smart protection with EzloPi
The following project leverages the MQ2 gas sensor and ACS712 current sensor with the EzloPi device for a reliable, real-time gas leakage and usage monitoring system. The MQ2 sensor detects gas concentrations, including propane, methane, and smoke, while the ACS712 sensor monitors the appliance’s power consumption. Together, they enhance safety by triggering an LED alert when gas levels exceed a safe threshold due to irregular power usage suggesting a malfunction. This system provides a simple yet effective solution for preventive safety in household appliances, ensuring user safety and resource efficiency.
Welcome to the project demonstration video section. The following video showcases the key aspects of Efficient gas monitoring, providing a visual walkthrough of its implementation.
  • MQ2 gas sensor with two 1K Ohm resistors.
  • ACS712 Current sensor.
  • LED with 100 Ohm Resistor.
From ESP32 to the MQ2 Gas sensor:
ESP32 MQ2 Resistor 1 Resistor 2
VIN VCC - -
GND GND - -
D13 D0 - -
- A0 Terminal 1 -
D33 - Terminal 2 Terminal 1
GND - - Terminal 2
From ESP32 to the FC-51 Proximity sensor:
ESP32 ACS712
VIN VCC
GND GND
D33 OUT
From ESP32 to the LED & Resistor:
ESP32 LED Resistor
D15 - Terminal 1
GND Cathode -
- Anode Terminal 2
4. Interfacing the Current Sensor & Gas sensor using the EzloPi Web Flasher:
Click Connect
  1. An Other window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to MQ2.
  • Set Device subtype to MQ2 LPG Gas Sensor.
  • Tick mark the boxes of GPIO 1 & GPIO2.
  • Set the GPIO 1 to 13.
  • Set the GPIO 2 to 32.
  • Then Click Apply Button.
  1. In the Device Configuration, tab click on Analog Input.
  1. An Analog Input window will be opened for inputting the following parameters:
  • Set a Device Name of your choosing. In our case, we set it to Current Sensor.
  • Set Device Subtype to CS712TELC 05B Current Sensor
  • Set the ADC input pin to 33.
  • Set the Resolution to 10-bit.
  1. In the Device Configuration, tab click on Digital Output
  1. A Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the LED.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 15.
  • Set the Resistor to PULL UP.
5. MiOS Web Dashboard
  1. Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have an ACS712 current sensor, MQ2 gas sensor and LED tile. The LED tile will indicate the status of the gas sensor and current sensor whether or not the sensor's values are within the set threshold.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Local.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test011.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to MQ2_digi..
  • Set the Capability to parent_abstract.
  • Set the variables to uuid.
  • Set the Comparator to Greater(>).
  • Set the Value Type to value.
  • Set the value to 400.
  • Add another trigger by pressing the Add Trigger button.
  • Set the Node to Current Sensor.
  • Set the value to 4.00.
  1. Set these values in the TRUE part of the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  • Now Click the Save button.
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Now, in the MiOS web dashboard, we can see that when the current passing through current sensor is normal value and within in our range whereas gas sensor value is also in the normal range, therefore our LED is OFF according to the condition set in the meshbot.
  1. Here in the above picture, it now shows that when the gas concentration becomes very high and also current value gets out of the set limit, the LED turns ON because of our meshbot settings.
6. MiOS App
Google PlayApple App Store
  1. On the MiOS mobile app, you will be able to see the tiles of connected devices. In our case, we have an ACS712 current sensor, MQ2 gas sensor and LED tile. The LED tile will indicate the status of the gas sensor and current sensor whether or not the sensor's values are within the set threshold.
Buy Components
