Smart home management with EzloPi
Dynamic temperature control and device monitoring
The project focuses on dynamic temperature control and device monitoring using the DS18B20 temperature sensor and a voltage sensor module interfaced with the EzloPi device. The DS18B20 provides real-time temperature data, while the voltage sensor monitors the power supply which is the battery in this case. Based on temperature readings, a 5V DC fan is turned on to maintain optimal conditions. The EzloPi device acts as the central controller, processing sensor inputs and triggering actions. This setup enables efficient cooling, temperature regulation, and power monitoring, making it ideal for smart environments and device management systems.
- DS18B20 temperature Sensor.
- Voltage sensor module.
- XY-MOS, high-power dual MOSFET driver module.
- 5V DC Fan.
- 3.7V battery
From ESP32 to the DS18B20:
| ESP32 | DS18B20 |
| 3V3 | VIN |
| GND | GND |
| D15 | S (Signal) |
From ESP32 to the Voltage sensor:
| ESP32 | Voltage sensor |
| VIN | + (VCC) |
| GND | - (GND) |
| D33 | S (Signal) |
From Voltage Sensor to Battery:
| Voltage sensor | Battery |
| VCC | + (VCC) |
| GND | - (GND) |
From ESP32 to the MOSFET driver module:
| ESP32 | MOSFET driver |
| D22 | Trig |
| VIN | VIN+ |
| GND | GND, VIN- |
From MOSFET driver module to Fan:
| MOSFET Driver | Fan |
| OUT+ | 5V |
| OUT- | GND |
4. Interfacing the Temperature sensor, voltage sensor module and fan using the EzloPi Web Flasher:
Click Connect
- In the Device Configuration, tab click on One Wire.
- A One Wire window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to DS18B20.
- Set the GPIO to 15.
- Set Device subtype to DS18B20 Temperature Sensor.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Analog Input.
- An Analog Input window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to Voltage Sensor.
- Set the Device Subtype to Shunt Voltmeter.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit.
- Again, In the Device Configuration, tab click on Digital Output
- A Digital Output window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to the Fan.
- Set Device Subtype to LED.
- Set the OUT GPIO to 22.
5. MiOS Web Dashboard
- Here, on the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case, we have a voltage sensor, DS18B20 and Fan tiles. The fan tile will depend on the output of the DS18B20 temperature sensor whether or not the sensor’s value is within the set temperature threshold while the voltage sensor indicates the battery voltages connected to our project setup.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test016.
- Set Node Type to Device.
- Set the Node to DS18B20.
- Set the Capability to Temp.
- Set the Comparator to Greater(>).
- Set the Value to 30.
- Set these values in the True part of the ACTION section.
- Set the Controllable to Fan.
- Set the Capability to switch.
- Set the Value to true.
- Set these values in the False part of the ACTION section.
- Set the Value to false.
- Now Click the Save button.
- Now in the MiOS web dashboard, we can see that when the temperature sensor temperature is within our limit, the fan is OFF according to the condition set in the meshbot while voltage sensor shows no power is being used and battery is at its full capacity.
- Here in the above picture, it shows that when the temperature measures a relatively high value and is out of our range then the fan turns ON because of our meshbot settings while the voltage sensor also shows that battery power is being consumed.
6. MiOS App
- On the MiOS mobile app, we can see that when the temperature sensor temperature is within our limit, the fan is OFF according to the condition set in the meshbot while voltage sensor shows no power is being used and battery is at its full capacity.
