Dual Scan Effect using Addressable LED
Dual Scan effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Dual Scan” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of Dual Scan Effect using Addressable LED, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
| Addressable LED Strip | ESP32 |
| LED Data (Din) | RX2 (GPIO16) |
5. MiOS Web Dashboard
- Under Effect mode, click on Dual Scan to apply this effect. By following the above steps, we can successfully implement a Dual Scan effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of your IoT lighting setup.
