DHT11 Temperature & Humidity Sensor
In this example, the DHT11 sensor is interfaced with the EzloPi device. The DHT11 sensor offers a comprehensive and reliable solution for monitoring the temperature and humidity levels.
The DHT11 sensor is an affordable yet reliable sensor for temperature and humidity monitoring. With the DHT11 we can optimize heating and cooling systems based on real-time data to ensure a comfortable indoor environment by maintaining ideal climate conditions. This powerful combination combines the versatility of the ESP32 microcontroller and the accuracy of the DHT11 sensor to provide real-time environmental data and control settings remotely via the MiOS app on a smartphone or web interface.
Welcome to the project demonstration video section. The following video showcases the key aspects of DHT11 Temperature & Humidity Sensor, providing a visual walkthrough of its implementation.
  • DHT11 Temperature & Humidity Sensor.
The wiring diagram for ESP32 30 pin is represented as follows:
From ESP32 to DHT11 Sensor:
  • Connect 3V3 from the ESP32 to the VCC of the sensor.
  • Connect GND from the ESP32 to the GND pin of the sensor.
  • Connect D4 from the ESP32 to the DATA pin of the sensor.
4. Interfacing the DHT11 Sensor using EzloPi Web Flasher
1. Set up your device/hardware by visiting config.ezlo.com
Touch Sensor Digital Module
Click Connect.
  2. In the Device Configuration, tab click on One Wire.
  1. A One Wire window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to DHT11.
  • Set OUT GPIO to 4.
  • Set Device subtype to DHT11 Temperature Humidity Sensor.
  • Now Click the Apply button.
5. MiOS App
Google PlayApple App Store
MiOS App
MiOS
  1. Here, as you can see in the MiOS mobile app above, two DHT11 tiles are being displayed. The upper box in the second tile shows the temperature being detected by the sensor and the lower box in that same tile shows the humidity levels being detected by the sensor. Additionally, we can also view the humidity value in a separate tile as well.
6. MiOS Web Application
Login to MiOS App
  1. As displayed above in the web dashboard, two DHT11 tiles are displayed. The upper box in the second tile shows the temperature being detected by the sensor and the lower box in that same tile shows the humidity levels being detected by the sensor. Additionally, we can also view the humidity value in a separate tile as well.
Buy Components
