Keep your plants healthy with EzloPi!
Detecting soil moisture levels using HD-38 soil moisture sensor
Before moving into this example, it is very important to know about the device registration, provisioning and converting the ESP32 device into an EzloPi device along with knowledge of Web Flasher, MiOS Mobile Application for Android/iOS and the MiOS Web Application..
This project aims to demonstrate how we can interface the soil moisture and humidity sensor with the EzloPi device to transform the sensor into a smart device for measuring the water levels or moisture levels of the soil for optimal growth of the plants. By interfacing the sensor with the EzloPi device, we can remotely monitor the moisture levels of the soil through the MiOS user-friendly interface. This integration can allow for automated watering systems, providing an efficient and convenient way to maintain optimal soil conditions for plants.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to detect the soil moisture levels using HD-38 soil moisture sensor, providing a visual walkthrough of its implementation.
The following components are required for interfacing using the EzloPi device:
- ESP32 as EzloPi smart device.
- HD-38 Soil moisture and humidity sensor module.
The following connections are made in order to complete the entire circuit setup:
From ESP32 to the HD-38 Soil moisture & Humidity Sensor Module:
| ESP32 | HD-38 module |
| 3V3 | VCC |
| GND | GND |
| D15 | DO |
| D33 | AO |
| HD-38 module | Sensor probe |
| + | 1st terminal |
| - | 2nd terminal |
4. Interfacing the LDR sensor module using EzloPi Web Flasher
Click Connect.
- Set a device name of your choosing. In our case we set it to Soil Moisture Sensor.
- Set the Device Sub Type to Soil Moisture Sensor.
- Set the ADC input pin to 33.
- Then Click Apply Button.
5. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- After opening the MiOS mobile app, we can see the moisture sensor tile which shows the amount of moisture in the soil.
6. MiOS Web Application
- After opening the MiOS web dashboard, we can see the moisture sensor tile which shows the amount of moisture in the soil.
