Darkness detection using KY-33 line sensor
Smart innovation made easier!
The following project involves interfacing the KY-33 line sensor with the EzloPi device to create a system for darkness detection. The KY-33 sensor is typically used for line-following robots, and can detect variations in light intensity. By connecting this sensor to the EzloPi device, the system will monitor ambient light levels. When the sensor detects a drop in light intensity indicating darkness, the EzloPi device will trigger predefined actions, such as turning on lights or sending notifications to users via email. This setup leverages the KY-33's sensitivity and the EzloPi device’s processing capabilities to create an efficient and responsive darkness detection solution.
Welcome to the project demonstration video section. The following video showcases the key aspects of Darkness detection using KY-33 line sensor, providing a visual walkthrough of its implementation.
  • KY-033 Line tracking sensor module.
  • LED with 100 Ohms resistor.
From ESP32 to KY-033:
ESP32 KY-033
3V3 VCC
GND GND
D21 OUT
From ESP32 to LED & Resistor:
ESP32 LED Resistor
D4 Anode -
GND - 1st Terminal
- Cathods 2nd Terminal
4. Interfacing the Line tracking sensor using the EzloPi Web Flasher
Click Connect
  2. In the Device Configuration, tab click on Digital Input.
  1. A Digital Input window will be opened for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to KY-033 Line Tracking Sensor.
  • Set the Input GPIO to 21.
  • Set Device Subtype to IR Proximity Sensor.
  • Then Click Apply Button.
  1. In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case we set it to LED.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 4.
  • Set Resistor to PULL UP.
5. MiOS Web Dashboard
  1. As you can see in the MiOS web dashboard, we can see the KY-33 sensor tile and LED tile.
MeshBots:
  1. On the right side of the screen under Automation, click on MeshBots.
  1. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  2. After clicking on Create new MeshBot you will see new options, click on EzloPi.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
  1. Set these values in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to Reed Switch.
  • Set the Capability to Dw state.
  • Set the value to dw_is_opened.
  1. Set these values in the True part of the ACTION section.
  • Set Controllable Type to LED.
  • Set the Capability to Switch.
  • Set the value to true.
  1. Set these values in the False part of the ACTION section.
  • Set the value to false.
  1. After clicking the apply button you can see a table of your setting in the Current configuration tab.
  1. Here, it can be seen that when the KY-33 sensor tile turns on which indicates that it is detecting darkness, the LED also turns on because of the rules we have set in the meshbot.
6. MiOS App
Google PlayApple App Store
  1. After opening the dashboard, you will be able to see the tile of your connected device. As you can see in the MiOS mobile app dashboard, we can see the KY-33 sensor tile and LED tile.
Buy Components
