Monitor your temperatures with ease!
Cooling your PC’s temperature using fan speed
The objective of this project can be achieved by controlling the fan speed for cooling your personal computer. Using the XY-MOS high-power MOSFET driver along with a 12V DC fan connected to the EzloPi device, this setup enables dynamic fan speed adjustments to optimize cooling while minimizing noise. The MOSFET driver allows precise control over the fan’s power, ensuring that the fan operates only when necessary, based on temperature thresholds. The system can be made to monitor CPU or case temperatures and adjust fan speeds accordingly, making it ideal for maintaining optimal performance and prolonging component lifespan.
Welcome to the project demonstration video section. The following video showcases the key aspects of Cooling your PC’s temperature using fan speed, providing a visual walkthrough of its implementation.
- XY-MOS, high-power dual MOSFET driver module.
- 12V DC Fan
From ESP32 to the MOSFET driver module:
| ESP32 | MOSFET Driver |
| D13 | Trig |
| VIN | Supply+ |
| GND | GND, Supply- |
From MOSFET driver module to the Fan:
| MOSFET Driver | Fan |
| Load+ | 5V |
| Load- | GND |
4. Interfacing the Mosfet Driver with Fan using the EzloPi Web Flasher
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- In the Device Configuration, tab click on PWM.
- A PWM window will be opened for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we will set it to Fan Speed Control.
- Set Device Subtype to PWM Generic Load.
- Set the PWM_GPIO to 13.
- Set the Frequency(KHz) from the slider.
- Set the Resolution to 10-bits.
- Then Click Apply Button.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected device. We have a PWM tile which is used to control the speed of the fan.. In the above picture, we have only 10% of the total speed of the fan. Also we can turn ON and OFF the fan from the button on the top right corner of the tile.
- Now as seen in the above picture, we can see that now the speed of the fan is now increased to 50% of the total speed.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected device. We have a PWM tile which is used to control the speed of the fan.. In the above picture, we have only 10% of the total speed of the fan. Also we can turn ON and OFF the fan from the button on the top right corner of the tile.
