Controlling Multiple EzloPi devices with the MiOS App
The following project demonstrates how to interface two different EzloPi devices with the MiOS application.
In this project, we have interfaced two LEDs with two respective EzloPi devices and control these LED’s remotely. The project is to showcase one of the many capabilities and features of the EzloPi platform. We can also use various sensors and devices in place of the LED’s used. By interfacing multiple ESP32s, we can increase the number of I/O’s being utilized which consequently increases our capability to interface several sensors and devices.
- LED Light with a current-limiting resistor (100 ohms).
From ESP32 to the LED:
- Connect the shorter leg (cathode) of the LEDs to the GND pin of the ESP32.
- Connect the longer leg (anode) of the LED via a current limiting resistor as shown in the diagram above to the IO4 pin of the first ESP32 and the IO5 pin to the second ESP32.
4. Interfacing the LED with ESP32 using EzloPi Web Flasher
- Log in using the credentials that you just set earlier while signing up.
Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
Interfacing the LED to First ESP32 using the EzloPi Web Flasher:
- Set a Device Name of your choosing. In our case, we set it to First ESP32 LED.
- Set Device Subtype to LED.
- Set the _GPIO to 4.
- Set resistor pullup.
- Set Default value LOW.
- Now Click the Apply button.
- After clicking the apply button you can see a table of your settings in the device configuration tab.
Interfacing the LED to the second ESP32 using the EzloPi Web Flasher:
- Set a Device Name of your choosing. In our case, we set it to Second ESP32 LED.
- Set the _GPIO to 5.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device.
- Here as you can see above, we can see the LED tiles. When we tap on it, the LED can be switched ON or OFF and vice versa for both the EzloPi devices. This shows how we can interface multiple EzloPi devices with the MiOS app and control various devices and sensors at a time.
6. MiOS Web Application
- Here as you can see above, we can see the LED tiles. When we tap on it, the LED can be switched ON or OFF and vice versa for both the EzloPi devices. This shows how we can interface multiple EzloPi deviced with the MiOS app and control various devices and sensors at a time.
- Similarly, the above figure shows both LED’s switched ON by using the MiOS web app.
