In this project, we will interface four AC lamps with the EzloPi device by utilizing a 4-channel relay module which will perform as a switch for the lamps. This will enable users to remotely control the four AC lamps using the MiOS smart application. With just one tap, we can control the state of all the AC lamps. This project combines hardware and software components to provide a user-friendly and easy-to-use solution for managing lighting in a smart home environment and ultimately enhancing the user experience and increasing energy efficiency for our smart home.
With the EzloPi meshbots, we can set certain rules and actions according to our requirements and automate these tasks to perform certain actions which would fulfill our smart home requirement.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to control several AC lamps with one tap using EzloPi Platform, providing a visual walkthrough of its implementation.
- 4-channel 5V relay module.
- 4x AC lamps with holder and AC wire.
The wiring diagram for ESP32 is represented as below:
From ESP32 to the Relay module:
From Relay module to 220V AC Lamp and Main AC supply:
4. Interfacing the 4-channel relay module using the EzloPi Web Flasher
Click Connect.
- Set device name to Relay_IN.
- Set Device subtype to Relay.
- Set OUT GPIO to 18.
- Set Resistor to PULL UP.
- Set the default value to LOW.
- Then Click Apply Button.
- Again in the Device Configuration, tab click on Digital Output.
- Set device name to Relay_OUT1.
- Set OUT GPIO to 5.
- Again click on Digital Output:
- Set device name to Relay_OUT2.
- Set OUT GPIO to 4.
4. MiOS Web Application
- On the MiOS web dashboard, you will be able to see the tile for four relays, one for controlling and the other three are for output. These three relays will indicate the status of the first relay.
MeshBots:
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test003.
- Set Node Type to Device.
- Set the Node to Relay_IN.
- Set the Category to Switch.
- Set the value to True.
- Set the Controllable to Relay_OUT1.
- Set the Capability to switch.
- Set the Value to true.
- Add an ACTION again.
- Set the Controllable to Relay_OUT2.
- Set the Controllable to Relay_OUT3.
- Now Click the Save button.
- Set the Value to false.
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. The state of all the four AC lamps can be controlled by just touching on the tiles for the lamps connected to the relay modules.
- Currently, all the tiles for the relay are OFF, which indicates that all the AC lamps are OFF.
- Similarly, it can be seen that when the first relay is ON, it indicates that all four lamps are ON.
5. MiOS App
- After opening the MiOS mobile app dashboard, you will be able to see the tile of your connected device. The state of all the four AC lamps can be controlled by just touching on the tiles for the lamps connected to the relay modules.
