													Effortlessly control your motor with EzloPi!
Control motor direction using EzloPi MeshBots
The following project aims to integrate a DC motor with the EzloPi device for making it into a smart device, enabling users to control the motor's direction remotely through the MiOS smart app. This project provides a versatile and user-friendly solution for individuals seeking to automate and remotely manage their DC motor applications, such as blinds, curtains, or any other motorized systems by implementing meshbots to perform automation tasks on the actions or conditions set by the user.
- 2-channel 5V relay module.
- DC motor.
- External DC power source.
The wiring diagram for ESP32 30 pins is represented as follows:
From ESP32 30 pins to 2-channel relay module:
- Connect 3V3 from the ESP32 to the VCC of the module.
- Connect GND from the ESP32 to the GND pin on the module.
- Connect D5 from the ESP32 to the IN1 pin on the module.
- Connect D4 from the ESP32 to the IN2 pin on the module.
From 2-channel relay module to the DC motor:
- Connect the COM pin of the K1 relay on the relay module to the positive terminal of the DC motor.
- Connect the COM pin of the K2 relay on the relay module to the negative terminal of the DC motor.
From 2-channel relay module to the DC supply:
- Connect the NO of the K1 relay to the NO of the K2 relay on the relay module, then connect it to the positive terminal of the DC supply.
- Connect the NC of the K1 relay to the NC of the K2 relay on the relay module, then connect it to the negative terminal of the DC supply.
3. Interfacing the 2-channel relay using the EzloPi Web Flasher
Click Connect.
- Set a device name of your choosing. In our case we set it to Relay_1.
- Set the Out GPIO to 5.
- Set Device Subtype to Relay.
- Set Resistor to PULL UP.
- Set Default value to LOW.
- Now Click the Apply button
- Set a device name of your choosing. In our case, we set it to Relay_2.
- Set Device subtype to Relay.
- Set OUT GPIO to 4.
- Set the Default value to LOW.
- Now Click the Apply button.
- Set a device name of your choosing. In our case, we set it to Relay_3.
- Set OUT GPIO to 15.
- After clicking the apply button you can see a table of your setting in the Device configuration tab.
4. MiOS Web Application
- On the MiOS web dashboard, you will be able to see the tile for all the three relays. These tiles will indicate the status of the relays and also the direction of DC Motor.
Meshbots
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
- Set Node Type to Device.
- Set the Node to Relay_3.
- Set the Category to Switch.
- Set the value to True.
- In the TRUE part, Set these values in the ACTION section.
- Set the Controllable to Relay_1.
- Set the Capability to Switch.
- Set the Value to true.
- Now add another ACTION.
- Set the Controllable to Relay_2.
- Set the Value to false.
- Now Click the Save button.
- In the FALSE part, Set these values in the ACTION section.
- Now, in the MiOS web dashboard, you can see that when the Relay_3 is OFF then Relay_1 is OFF and Relay_2 is ON, which means that our DC motor is running in one direction.
- Now in the MiOS web dashboard, you can see that when the Relay_3 is ON then Relay_1 is ON and Relay_2 is OFF, which means that our DC motor is now running in the opposite direction.
5. MiOS App
- On the MiOS mobile dashboard, you can see that when the Relay_3 is OFF then Relay_1 is OFF and Relay_2 is ON, which means that our DC motor is running in one direction.
- Now, in the MiOS mobile dashboard, you can see that when the Relay_3 is ON then Relay_1 is ON and Relay_2 is OFF, which means that our DC motor is now running in the opposite direction.
