Control LED by LDR using meshbot
The aim of this project is to create a simple and effective system that utilizes the LM393 LDR (Light Dependent Resistor) sensor module to control the operation of an LED (Light Emitting Diode). The LM393 LDR sensor module detects ambient light levels and adjusts the LED output accordingly, and we can also create an automated lighting system using the EzloPi meshbot rules for seamless automation.
  • LM393 LDR module.
  • LED with a current limiting resistor of 82 Ohms.
The wiring diagram for ESP32 30 pins is represented as follows:
From ESP32 30 pins to LDR Module:
  • Connect 3V3 from the ESP32 to the VCC of the module.
  • Connect GND from the ESP32 to the GND pin on the module.
  • Connect D4 from the ESP32 to the D0 Pin on the LDR module.
From ESP32 30 pins to the LED:
  • Connect the D5 pin from the ESP32 to the LED anode (long leg) through a current limiting resistor of 82 Ohms.
  • Connect the GND to the cathode (short leg) of the LED.
3. Interfacing the Proximity Sensor with EzloPi Web Flasher:
Dimmable LED
Click Connect
  2. In the Device Configuration, tab click on Digital Input.
7. A Digital Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to LDR.
  • Set the Input GPIO to 4.
  • Set Device Subtype to LDR Sensor.
  • Now Click the Apply button.
8. Again in the Device Configuration, tab click on Digital Output.
9. A Digital Output window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to LED.
  • Set Device subtype to LED.
  • Set OUT GPIO to 5.
  • Set Resistor to PULL UP.
10. A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
11. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
4. MiOS Web Application
Login To MiOS
  1. Now, on the MiOS web dashboard, you will be able to see the tile for the LED. The tile will indicate the status of the LED depending on the light being detected by the sensor.
MiOS Dashboard
  1. On the right side of the screen under Automation, click on MeshBots.
Create a New Meshbot
  1. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  2. After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
Create Meshbot
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test002.
Meshbot Choose Meshbot
  1. In the trigger tap you can set the TRIGGER for your device and in the ACTION tab you can set the action to be performed based on the trigger which you have created.
Meshbot Add Trigger
9. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to LDR.
  • Set the Category to power.
  • Set the variables to status.
  • Set the Comparator to Not equal (!=).
  • Set the Value Type to value.
  • Set the value to true.
Meshbot Add Action
10. Set these values in the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  • Now Click the Save button.
  • After clicking the apply button you can see a table of your setting in the Current configuration tab.
Meshbot Saved
Meshbot Save Button
  1. Here you can see your saved MeshBot. Now click on Dashboard.
  1. Here in the MiOS web dashboard, you can see when the LDR sensor is placed in the absence of light. It triggers the LED on because of the rules we have set in meshbot.
Meshbot MiOS Web Dashboard
  1. And when the LDR sensor is placed in the presence of light, it triggers the LED to be turned Off because of the rules set in the meshbot.
5. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
  1. Here, as you can see when the LDR sensor is placed in the absence of light, it triggers the LED on because of the rules we have set in meshbot.
  1. And when the LDR sensor is placed in the presence of light ,it triggers the LED off  because of the rules set in the meshbot.
Buy Components
