Control LED by IR Proximity Sensor using meshbot
The aim of this project is to create a simple and effective system that utilizes the IR Proximity Sensor module to control the operation of an LED (Light Emitting Diode). The IR Proximity Sensor module detects motion of an  object or body and will adjust the state of the LED output accordingly. This project can be utilized by using meshbots to perform automation tasks on the actions or sensing performed by the sensor according to the conditions set by the user.
  • FC-51 Infrared (IR) Proximity Sensor.
The wiring diagram for ESP32 30 pins is represented as follows:
Wiring Diagram
Circuit Setup
From ESP32 30 pins to FC-51 Infrared (IR) Proximity Sensor:
  • Connect 3V3 from the ESP32 to the VCC of the module.
  • Connect GND from the ESP32 to the GND pin on the module.
  • Connect D4 from the ESP32 to the D0 Pin on the LDR module.
From ESP32 30 pins to the LED:
  • Connect the D5 pin from the ESP32 to the LED anode (long leg) through a current limiting resistor of 82 Ohms.
  • Connect the GND to the cathode (short leg) of the LED.
3. Interfacing the IR Proximity Sensor using the EzloPi Web Flasher:
Dimmable LED
Meshbot Login
Meshbot Connected Devices
Click Connect
Meshbot Click Connect
  2. In the Device Configuration, tab click on Digital Input.
Meshbot Device Configuration
7. A Digital Input window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case we set it to IR Proximity Sensor.
  • Set the Input GPIO to 4.
  • Set Device Subtype to IR Proximity Sensor..
  • Now Click the Apply button.
8. Again in the Device Configuration, tab click on Digital Output.
Meshbot Digital Output
9. A Digital Output window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to LED.
  • Set Device subtype to LED.
  • Set OUT GPIO to 5.
  • Set Resistor to PULL UP.
  • Set the default value to LOW.
10.A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
Meshbot BOOT
11. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
Meshbot Installation
Meshbot Device Flashed
4. MiOS Web Application
Login To MiOS
Meshbot Web Flasher
  1. Now, on the MiOS web dashboard, you will be able to see the tile for the LED. The tile will indicate the status of the LED depending on the light being detected by the sensor.
MiOS Dashboard
  1. On the right side of the screen under Automation, click on MeshBots.
Create a New Meshbot
  1. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  2. After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
Create Meshbot
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test001.
Meshbot Choose Meshbot
  1. In the trigger tap you can set the TRIGGER for your device and in the ACTION tab you can set the action to be performed based on the trigger which you have created.
Meshbot Add Trigger
9. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to IR Proximity Sensor.
  • Set the Category to power.
  • Set the variables to status.
  • Set the Comparator to Equal (==).
  • Set the Value Type to value.
  • Set the value to true.
Meshbot Add Action
9. Set these values in the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  • Now Click the Save button.
Meshbot Saved
Meshbot Save Button
  1. Here you can see your saved MeshBot. Now click on Dashboard.
Meshbot Saved Meshbot
  1. Here in the MiOS web dashboard, you can see that when the IR proximity sensor gets triggered. The LED turns on because of the rules we have set in meshbot.
Meshbot MiOS Web Dashboard
  1. And when the LDR sensor is placed in the presence of light, it triggers the LED to be turned Off because of the rules set in the meshbot.
5. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
Meshbot Controller
  1. Here, as seen on the MiOS mobile dashboard, when the IR Proximity Sensor gets  triggered, it turns the LED on because of the rules we have set in meshbot.
Buy Components
