Control DC Load (DC Motor) with high power MOSFET driver
In this project, we will be interfacing a 12V DC motor as our DC load with the help of a high-power MOSFET driver module. The primary objective is to seamlessly connect this motor control system to the EzloPi device, which opens up a world of possibilities for smart and efficient automation, and also incorporate high-load driving capabilities into various IoT projects. The following project is capable of driving a DC load of up to 350 watts.
2. Circuit Setup & Interfacing – XY-MOS Schematic
  • XY-MOS, High-power dual MOSFET driver module.
  • DC load (12V DC motor)
XY-MOS Schematic Diagram
Motor Circuit Setup
The following connections are made in order to complete the entire circuit setup:
From ESP32 to the MOSFET driver module:
  • Connect GND from the ESP32 to the GND pin on the module.
  • Connect D21 from the ESP32 to the TRG pin on the module.
From External Power Source to the MOSFET driver module:
  • Connect the positive terminal of the external power source to the VIN+ pin.
  • Connect the negative terminal of the external power source to the VIN- pin.
From MOSFET driver to the DC Motor:
  • Connect the OUT+ pin to the positive terminal on the DC Load (DC Motor).
  • Connect the OUT- pin to the negative terminal on the DC Load (DC Motor).
3. Interfacing the MOSFET driver module with DC Load (DC Motor) using the EzloPi Web Flasher
Dimmable LED
DC Motor Login
DC Motor Connect Device
Click Connect
DC Motor Configuration
7. A Digital Output window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to DC Load (DC Motor).
  • Set Device subtype to Relay.
  • Set OUT GPIO to 4.
  • Set Resistor to PULL UP.
  • Set the default value to LOW.
  • Now Click the Apply button.
8. A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
Control DC Load (DC Motor) Button
9. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
Control DC Load (DC Motor) Installation
4. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. Here as can be seen above, we have successfully interfaced a DC motor with our EzloPi device and with the MiOS app we can turn on or off the DC motor.
5. MiOS Web Application
Login To MiOS
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. The DC motor can be controlled easily using the MiOS app after it is successfu;lly interfaced with the EzloPi device.
Buy Components
