The objective of this project is to interface an LED strip (consisting of 24 LEDs) with the EzloPi device which will be used as a mini book light. PWM signal is generated to modulate the gate voltage of the MOSFET for controlling the LED brightness through pulse-width modulation. The high-power MOSFET driver module acts as a switch, regulating the current flowing through the LED strip. Users will be able to easily control the brightness of the book light using the MiOS application.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to adjust the brightness level of mini book light with high power MOSFET trigger, providing a visual walkthrough of its implementation.
- XY-MOS, high-power dual MOSFET driver module.
- 24 LEDs mini portable lamp.
From ESP32 to the MOSFET driver module:
From MOSFET driver module to book light:
4. Interfacing the MOSFET driver module using the EzloPi Web Flasher
Click Connect.
- In the Device Configuration, tab click on PWM.
- A PWM window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Dimmer.
- Set Device subtype to Dimmable Lamp.
- Set OUT GPIO to 5.
- Set frequency by dragging the slider.
- Set the resolution which is 8-bit in our case.
- Set Duty Cycle from its slider.
- Then Click Apply Button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. Here as seen above, we have interfaced the LED strip with our EzloPi device and with the MiOS app we can turn on or off the strip and also adjust its brightness.
- Here, we can see that we have turned on the LED strip and set its brightness according to our requirement.
- Similarly, when the KY-024 does not detect any magnetic field or object, the tile will display the “Open” message as depicted in the above image.
6. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. You can turn on/off the LED strip and also adjust its brightness by using the slider.
- The LED strip can be controlled easily using the MiOS dashboard after it is successfully interfaced with the EzloPi device.
