Make your smart home light up with EzloPi!
Control brightness of flexible Neon LED strip using MOSFET driver
1. About this Example - LED Mosfet Driver
This project aims to interface a flexible neon light strip (Red) with the EzloPi device, providing users with convenient control over its brightness. By integrating the Neon light strip with EzloPi, users can remotely adjust brightness levels through the MiOS app’s user-friendly interface, enhancing customization and ambiance in various settings. Leveraging EzloPi's capabilities, the project ensures seamless communication between the device and the Neon light strip, enabling real-time adjustments via Wi-Fi connectivity.
Additionally, the project focuses on simplicity and efficiency, allowing users to effortlessly manage the brightness of the Neon light strip using their smartphones or other connected devices. Overall, this integration offers an innovative solution for personalized lighting control, enhancing user experience and flexibility in a smart home or commercial environments.
Welcome to the project demonstration video section. The following video showcases the key aspects of Control brightness of flexible Neon LED strip using MOSFET driver, providing a visual walkthrough of its implementation.
- XY-MOS, high-power dual MOSFET driver module.
- 24 LEDs mini portable lamp.
- 12V power source
From ESP32 to the MOSFET driver module:
| ESP32 | MOSFET driver |
| D5 | Trig |
| GND | GND |
From MOSFET driver module to LED Strip:
| MOSFET driver | 24 LED Strip |
| OUT+ | 5V |
| OUT- | GND |
From 12V Power supply to MOSFET driver module:
| 12V Power Supply | MOSFET driver |
| VCC | VIN+ |
| GND | VIN- |
4. Interfacing the MOSFET driver module using the EzloPi Web Flasher
1. Set up your device/hardware by visiting https://config.ezlopi.com/
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- In the Device Configuration, tab click on PWM.
- A PWM window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Dimmer.
- Set Device subtype to Dimmable Lamp.
- Set OUT GPIO to 5.
- Set frequency by dragging the slider.
- Set the resolution which is 8-bit in our case.
- Set Duty Cycle from its slider.
- Now Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. Here as seen above, we have interfaced the LED strip with our EzloPi device and with the MiOS app, we can turn on or off the LED strip and also adjust its brightness.
- Here, we can see the LED strip is turned on and brightness is set according to our requirement.
6. MiOS Web Dashboard
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. Here as seen above, we have interfaced the LED strip with our EzloPi device and with the MiOS app, we can turn on or off the LED strip and also adjust its brightness.
- The LED strip can be controlled easily using the MiOS dashboard after it is successfully interfaced with the EzloPi device. Here, we can see the LED strip is turned on and brightness is set according to our requirement.
