Discover smart switching with EzloPi!
Control AC lamps using solid-state relay
This project aims to control two AC lamps using solid-state relays (SSR) and push buttons, interfaced with the EzloPi device. The SSRs ensure safe and efficient switching of the AC lamps, while the push button offers a user-friendly way to toggle each lamp on or off. By integrating the EzloPi device, the system allows for custom control logic and expansion to additional features, such as remote operation or integration with sensors. This setup is ideal for applications where safe and reliable control of AC lighting is required, such as in automated home or industrial lighting systems.
Welcome to the project demonstration video section. The following video showcases the key aspects of Control AC lamps using solid-state relay, providing a visual walkthrough of its implementation.
- Dual-channel solid state relay.
- Two push buttons
- Two AC lamps
From ESP32 to Two Push Buttons:
| ESP32 | Push Button 1 | Push Button 2 |
| GND | Terminal 1 | Terminal 1 |
| D14 | Terminal 2 | - |
| D27 | - | Terminal 2 |
From ESP32 to Dual Channel Solid State Relay:
| ESP32 | Solid State Relay |
| VIN | DC+ |
| GND | DC- |
| D13 | CH1 |
| D12 | CH2 |
From Solid State Relay to AC Lamp & 220V:
| Solid State Relay | AC Lamp 1 | AC Lamp 2 | 220V |
| SW1-1 | - | - | Neutral |
| SW1-2 | Terminal 1 | - | - |
| SW2-1 | - | - | Neutral |
| SW2-2 | - | Terminal 1 | - |
| - | Terminal 2 | Terminal 2 | Phase |
4. Interfacing the Solid state relays & Push buttons using the EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case, we set it to the Push Button 1.
- Set INPUT GPIO to 14.
- Set Device Subtype to Switch / Push Button / Key.
- Set Resistor to PULL UP.
- Then Click Apply Button.
- Set a Device name of your choosing. In our case, we set it to the Push Button 2.
- Set INPUT GPIO to 27.
- In the Device Configuration, tab click on Digital Output
- Set a Device name of your choosing. In our case, we set it to Lamp 1.
- Set Device Subtype to Relay.
- Set OUT GPIO to 13.
- Set a Device name of your choosing. In our case, we set it to Lamp 2.
- Set OUT GPIO to 12.
5. MiOS Web Dashboard
- In the MiOS web dashboard, you will be able to see the tiles for the push buttons and for the lamps which are outputs of 2-channel solid state relay. These tiles indicate the state of the solid state relay depending on whether the push buttons are being turned triggered as ON or OFF.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test009.
- Set Node Type to Device.
- Set the Node to Push Button 1.
- Set the Capability to power.
- Set the Variables to status.
- Set the Comparator to Equal(==).
- Set the value to true.
- Set the Controllable to Lamp 1.
- Set the Capability to power_command.
- Set the Value Type to set.
- Set the Value to true.
- Now Click the Save button.
- Again Create new meshbot by clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test0009.
- Set the Node to Push Button 2.
- Set the Controllable to Lamp 2.
- Now, on the MiOS web dashboard, you can see that when the first push button is turned ON, the first channel of the SSR module which is connected to Lamp 1 gets turned ON, whereas the second push button is OFF therefore Lamp 2 which is connected to the second channel of SSR module also remains OFF because of the logic we have set in the meshbot.
- Here, in the above picture, we can see that when second push button is turned ON, Lamp 2 which is connected to second channel of SSR module also turns ON while first push button is turned OFF therefore the Lamp 1 which is connected to first channel of the SSR is also turned OFF because of our meshbot settings.
6. MiOS App
- On the MiOS mobile dashboard, you can see that when the first push button is turned ON, the first channel of the SSR module which is connected to Lamp 1 gets turned ON, whereas the second push button is OFF therefore Lamp 2 which is connected to the second channel of SSR module also remains OFF because of the logic we have set in the meshbot.
