Smart monitoring with EzloPi!
Comprehensive weather monitoring station
The following project integrates the BMP280 and DHT22 sensors with the EzloPi device for accurate environmental monitoring. The BMP280 sensor provides temperature, humidity, and atmospheric pressure data, while the DHT22 enhances the setup with additional temperature and humidity readings, offering redundancy. Together, these sensors enable detailed weather analysis and support precise monitoring of local climate conditions. This system is ideal for applications that require real-time, accurate weather data and can serve as a foundation for advanced projects like climate control, smart agriculture and environmental studies.
Welcome to the project demonstration video section. The following video showcases the key aspects of Comprehensive weather monitoring station, providing a visual walkthrough of its implementation.
- BMP280 temperature, humidity and pressure sensor.
- DHT22 temperature and humidity sensor
From ESP32 to the BMP280:
| ESP32 | BMP280 |
| VIN | VCC |
| GND | GND |
| D21 | SDA |
| D22 | SCL |
From ESP32 to the DHT22:
| ESP32 | DHT22 |
| 3V3 | VCC |
| GND | GND |
| D15 | Data-Signal |
4. Interfacing the BMP280 & DHT22 using the EzloPi Web Flasher
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- An I2C window will open for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to BMP280.
- Set Device Subtype to BMP280 I2C Sensor.
- Set the Slave address to 118.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark both boxes of Enable pullup.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on One Wire.
- A One Wire window will open for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to DHT22.
- Set the GPIO pin to 15.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. We have BMP280 and DHT22 sensors, the BMP280 and DHT22 both show the temperature and humidity values so that we can use them both to analyze the weather data.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. We have BMP280 and DHT22 sensors, the BMP280 and DHT22 both show the temperature and humidity values so that we can use them both to analyze the weather data.
