													Smart safety with EzloPi!
Collision detection using accelerometer and ultrasonic sensor
The collision detection system leverages an accelerometer (ADXL345) and an ultrasonic sensor (HC-SR04) interfaced with the EzloPi device for enhanced safety and navigation. The accelerometer monitors sudden changes in acceleration or tilt, indicating potential impacts or instability. Simultaneously, the ultrasonic sensor detects nearby obstacles by measuring distance using sound waves. Combined, these sensors provide real-time feedback, enabling the system to prevent collisions effectively. This dual-sensor integration is ideal for applications in vehicle safety, robotics and marine navigation. The EzloPi device ensures seamless sensor interfacing, efficient data processing, and configurable outputs such as alarms or automated controls.
- ADXL345 3-axis accelerometer.
- HC-SR04 Ultrasonic sensor.
From ESP32 to the ADXL345:
| ESP32 | ADXL345 |
| 3V3 | VCC |
| GND | GND |
| D21 | SDA |
| D22 | SCL |
From ESP32 to the HC-SR04:
| ESP32 | HC-SR04 |
| VIN | VCC |
| GND | GND |
| D13 | ECHO |
| D23 | TRIG |
4. Interfacing the ADXL345 3-Axis Accelerometer & Ultrasonic sensor with the EzloPi Web Flasher
Click Connect
- If you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- An I2C window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to ADXL345.
- Set the Device Subtype to ADXL345 3-Axis Accelerometer.
- Set the Slave Address to 89.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark the Button Enable Box.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Other
- An Other window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to Ultrasonic Sensor.
- Set the Device Subtype to Ultrasonic Sensor HC SR04.
- Tick mark both boxes of GPIO1 & GPIO2.
- Set the GPIO1 pin to 13.
- Set the GPIO2 pin to 23
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. Here, we have an ADXL345 accelerometer module and Ultrasonic distance sensor which can be used to efficiently prevent robots from hitting obstacles. ADXL345 measures the accelerometer data of 3-axes which help in tilt movement or help in orientation whereas ultrasonic sensor give the distance from obstacles.
- Here, In the above picture we can see that ADXL345 is currently showing orientation of the robot while the ultrasonic distance sensor shows distance data. By these two sensors, we can effectively avoid any obstacle and also monitor the robot's orientation and tilting.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. Here, we have an ADXL345 accelerometer module and Ultrasonic distance sensor which can be used to efficiently prevent robots from hitting obstacles. ADXL345 measures the accelerometer data of 3-axes which help in tilt movement or help in orientation whereas the ultrasonic sensor give the distance from obstacles.
