Built-In Hall Effect Sensor
The Hall effect sensor is a transducer that detects changes in magnetic fields. When a magnetic field is present, it generates a voltage proportional to the strength of the field. This voltage can be used to determine the presence, strength, or orientation of a magnet or magnetic field source.
The EzloPi device based on ESP32 hall sensor comes equipped with a built-in Hall effect sensor, which can prove to be a valuable component for detecting magnetic fields and various applications like proximity sensing, rotation measurement, and more.
2. Circuit Hall Effect Sensor Diagram & Interface
  • A small magnet.
The hall sensor wiring diagram of ESP32 30 pin is represented as follows:
Hall Sensor Wiring Diagram
Hall Effect Sensor Breadboard
Note: There is no need for connections because we use the built-in Hall effect sensor.
The hall sensor wiring diagram of ESP32 38 pin is also represented as below:
Hall Effect Sensor ESP32 30-pin
3. Interfacing the Built-In Hall Effect Sensor using EzloPi Web Flasher
1. Set up your device/hardware by visiting config.ezlo.com
Login to MiOS Account
Device not Connected
  1. Now click on Connect Device and a pop-up window will appear
PCI Serial Port
Click Connect.
Connect to a Serial Port
  1. The Other window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to the Hall Effect Sensor.
  • Set Device Subtype to Internal Hall Effect Sensor.
  • Leave the GPIO settings without making any changes. As we are using the built-in Hall effect sensor, we don’t have to set any GPIO.
  • Now Click the Apply button. After clicking the apply button you can see a table of your setting in the device configuration tab.
Flashing Begins
  1. A window will appear on the bottom left side of the screen displaying “Please press BOOT button while flashing begins.”
  2. Hold the BOOT button down until the next window appears on the bottom left side of the screen which says “Installation prepared. Please release the boot button now.”
Installation Prepared
Device Flashed Successfully
4. MiOS App
Google PlayApple App Store
MiOS App
MiOS
Select a Location
  2. After opening the dashboard, you will be able to see the tile of your connected device.
Hall Effect Sensor Closed
  1. As you can see in the MiOS mobile dashboard, we can see the Hall effect sensor tile. When the ESP32 detects a magnetic field or object such as of a small magnet, the tile will display the “Closed” message as shown in the above image.
Hall Effect Sensor Open
  1. Similarly, when the ESP32 does not detect any magnetic field or object, the tile will display the “Open” message as depicted in the above image.
5. MiOS Web Application
MiOS Login
Hall Sensor Open
  1. Now, you will see a tile labeled as Water Leak on the web application UI , as there is no leak detected by the sensor therefore the water leak sensor tiles show the “No leak” message.
Hall Sensor Closed
  1. As seen in the MiOS web dashboard above, the Hall effect sensor tile is visible with the message “Open” which means that the built-in hall effect sensor is not detecting any magnetic object.
Buy Components
