BMP280 Pressure Sensor
The goal of this example is to elevate the capabilities of the EzloPi device by seamlessly integrating the BMP280 module, a cutting-edge environmental sensor. The BMP280 module offers high-precision measurements of temperature and pressure, enabling the EzloPi device to gather valuable data and provide real-time insights into the surrounding environment.
The BMP280-EzloPi interface offers an innovative solution for capturing precise environmental parameters for a wide range of applications, including weather monitoring, indoor climate control, altitude detection, and more. Users are also able to monitor real-time data with the help of the MiOS mobile app and web dashboard.
The following components are required for interfacing the BMP280 sensor module with the EzloPi device:
- ESP32 as EzloPi smart device.
- BMP280 Barometric Pressure & Altitude Sensor.
The wiring diagram of ESP32 32 pin is represented as follows:
From ESP32 (32 pins) to the BMP280:
- Connect the GND from the ESP32 to the GND pin of the BMP280.
- Connect the 3v3 pin from the ESP32 to the VCC or VIN pin.
- Connect the D21 pin from the ESP32 to the serial data (SDA) pin on the BMP280.
- Connect the D22 pin from the ESP32 to the serial clock (SCL) pin on the BMP280.
The wiring diagram of ESP32 38 pin is also represented as below:
From ESP32 (38 pins) to the BMP280:
- Connect the IO21 pin from the ESP32 to the serial data (SDA) pin on the BMP280.
- Connect the IO22 pin from the ESP32 to the serail clock (SCL) pin on the BMP280.
3. Interfacing the BMP280 Pressure Sensor using EzloPi Web Flasher
Click Connect.
- If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wifi SSID and Wifi Password.
- Set a device name of your choosing. In our case, we set it to BMP280.
- Set Device Sub Type to BMP280 I2C.
- Set the Slave Address to 118.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick the “Enable Pullup” for both the SDA and SCL.
- Now Click the Apply button. After clicking the apply button you can see a table of your setting in the device configuration tab.
4. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- As we can see above in the MiOS mobile app dashboard, the BMP280 sensor module tile is showing the current temperature and pressure values.
5. MiOS Web Application
- As seen in the web dashboard, the BMP280 module connected to the EzloPi device is displaying the ambient temperature and current pressure readings.
