Real time monitoring for a safe environment!
Bicolor Chase (sequential illumination of LEDs in two alternating colors) effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Bicolor chase” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to use EzloPi to interface an addressable LED strip and implementing a Bicolor Chase Effect, providing a visual walkthrough of its implementation.
From Power Supply to ESP32 and LED Strip:
Select EzloPi Addressable LED.
