Battery-powered Weather Monitoring using DHT11
This project aims to create a battery-powered weather monitoring system for a cost-effective, low-power, and portable weather monitoring solution using the ESP32 microcontroller, configured as an EzloPi device, and a DHT11 sensor. This project is ideal for remote locations or situations where a constant power source is not readily available, making it suitable for applications like home automation, agriculture, environmental monitoring, and home weather stations.
2. Project Video Demonstration
Welcome to the project demonstration video section. The following video showcases the key aspects of Create smart battery powered weather station using EzloPi platform and DHT11 sensor, providing a visual walkthrough of its implementation.
  • DHT11 Temperature and Humidity sensor.
  • Lithium Battery Shield (5V).
The wiring diagram for ESP32 is represented as follows:
The following connections are made in order to complete the entire circuit setup:
From ESP32 to DHT11 Temperature and Humidity sensor:
  • Connect the Positive terminal of the battery to the VIN of ESP32.
  • Connect the Negative terminal of the battery to the GND of ESP32.
  • Connect VIN from the ESP32 to the VCC of the sensor.
  • Connect GND from the ESP32 to the GND pin of the sensor.
  • Connect D4 from the ESP32 to the DATA pin of the sensor.
4. Interfacing the DHT11 sensor using the EzloPi Web Flasher
Dimmable LED
Click Connect
  2. In the Device Configuration, tab click on One Wire.
7. A One Wire window will open for inputting the following parameters:
  • Set a device name of your choosing. In our case, we set it to DHT11.
  • Set OUT GPIO to 4.
  • Set Device subtype to DHT11 Temperature Humidity Sensor.
  • Now Click the Apply button.
8. A window will appear on the bottom right side of the screen displaying “Please press BOOT button while flashing begins.”
9. Hold the BOOT button down until the next window appears on the bottom right side of the screen which says “Installation prepared. Please release the boot button now.”
5. MiOS App
Google PlayApple App Store
MiOS Installed App
MiOS Login
Controllers Connected
  1. Here, as you can see in the MiOS mobile app above, two tiles for the DHT11 sensor are being displayed. The upper box in the second tile shows the temperature being detected by the sensor and the lower box in that same tile shows the humidity levels being detected by the sensor. Additionally, we can also view the humidity value in a separate tile as well.
6. MiOS Web Application
Login To MiOS
  1. As displayed above in the web dashboard, two tiles for the DHT11 sensor are displayed. The upper box in the second tile shows the temperature being detected by the sensor and the lower box in that same tile shows the humidity levels being detected by the sensor. Additionally, we can also view the humidity value in a separate tile as well.
Buy Components
