Battery-powered smart load Indicator with LED
The battery-powered smart load indicator is a compact and efficient solution for real-time weight monitoring using a load cell with an HX711 weight sensor module. Powered by a 3.7V LiPo battery, the system incorporates a step-up boost converter to ensure stable voltage supply for the components. Two LEDs, connected via 120-ohm resistors, visually indicate weight thresholds, providing an intuitive alert system. Designed to interface seamlessly with the EzloPi device, this setup is ideal for portable weight monitoring applications, combining low power consumption with reliable performance.
  • MT3608 Step-up DC-DC boost converter
  • Load cell with HX711 weight sensor module.
  • Two LEDs with 120 Ohms Resistor.
  • 3.7V Lipo battery
From Battery to Boost Converter:
BatteryMT3608
BAT+VIN+
BAT-VIN-
From Boost Converter to ESP32:
MT3608ESP32
VOUT+VIN
VOUT-GND
From ESP32 to the HX711 module:
MT3608HX711
VINVCC
GNDGND
D12CK
D13DO
From HX711to the Load cell:
HX711Load Cell
E+Red
E-Black
A+Green
A-White
From ESP32 to the LED & Resistor:
ESP32LED1Resistor1LED2Resistor2
D15-Terminal 1--
D4---Terminal 1
GNDCathode1-Cathode2-
-Anode1Terminal 2--
---Anode2Terminal 2
4. Interfacing the load cell, weight sensor module & LEDs using the EzloPi Web Flasher:
Click Connect
  1. Other window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to HX711.
  • Set Device Subtype to HX711 LOADCELL.
  • Tick mark the GPIO1 and GPIO2 boxes.
  • Set the GPIO1 pin to 12.
  • Set the GPIO1 pin to 13.
  • Then Click Apply Button.
  1. In the Device Configuration, tab click on Digital Output.
  1. A Digital Output window will be opened for inputting the following parameters:
  • Set a Device name of your choosing. In our case, we set it to the LED 1.
  • Set Device Subtype to LED.
  • Set the OUT GPIO to 15.
  • Set the Resistor to PULL UP.
  • Set a Device name of your choosing. In our case, we set it to the LED 2.
  • Set the OUT GPIO to 4.
  • Now press the Flash Device Button.
5. MiOS Web Dashboard
  1. On the MiOS web dashboard, you will be able to see the tiles of connected devices. In our case we have a load sensor or weight sensor with two LED tiles for different load indications.
MeshBots:
  1. On the left side of the screen under Automation, click on MeshBots.
  2. On meshbot screen, click on Create new MeshBot button present on the top right corner of the screen.
  3. After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on Cloud.
  1. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test016.
  1. Set these things in TRIGGER section:
  • Set Node Type to Device.
  • Set the Node to HX711.
  • Set the Capability to parent_abstract.
  • Set the Variables to uuid.
  • Set the Comparator to Less (<).
  • Set the Value Type to value.
  • Set the Value to 0.25.
  1. Set these values in the ACTION section.
  • Set Controllable Type to Device.
  • Set the Controllable to LED 1.
  • Set the Capability to power_command.
  • Set the Value Type to set.
  • Set the Value to true.
  • Now Click the Save button.
  1. Again Click on Create new Meshbot and under Automation MeshBot click on Cloud.
  2. On the next screen you will see that we can create a name of our choosing, in this case we write it as Test017.
  • Set the Comparator to Greater (>).
  • Set the Controllable to LED 2.
  1. Here, you can see your saved MeshBot. Now click on Dashboard.
  1. In the MiOS web dashboard, it can be seen that the load sensor is showing some load value because we have placed an empty glass on the base of load cell that is why LED1 is triggered ON while LED2 remained OFF due to condition we have set in the meshbot.
  1. Here in the above picture, it shows that when we have placed a full glass of water on the base of the load cell then it shows a different load reading on it, so now LED2 is triggered ON while LED1 now turned OFF because of our meshbot setting.
6. MiOS App
Google PlayApple App Store
  1. On the MiOS mobile app, it can be seen that the load sensor is showing some load value because we have placed an empty glass on the base of load cell that is why LED1 is triggered ON while LED2 remained OFF due to condition we have set in the meshbot.
Buy Components
