Precision temperature monitoring with EzloPi!
Battery-operated digital temperature sensor
The following projects aims to create a seamless and intelligent integration between the KY-001 digital temperature sensor module and the EzloPi device. This designed temperature monitoring system will be operated via a 5V battery system.
With the user-friendly MiOS mobile and web application, users can remotely access and monitor the temperature information and make informed decisions to optimize energy consumption and enhance comfort. This also allows for intelligent automation, allowing users to set custom triggers and actions based on temperature thresholds values, enhancing energy efficiency and comfortable living.
The following components are required for interfacing the digital temperature sensor module with the EzloPi device:
- KY-001 module with DS18B20 Digital temperature sensor.
- 5V Battery module
The following connections are made in order to complete the entire circuit setup:
From ESP32 (30 pins) to the KY-001 module:
| ESP32 | KY-001 |
| 3V3 | Vin |
| GND | – |
| D4 | S |
From ESP32 (30 pins) to the Battery:
| ESP32 | Battery |
| Positive terminal | Vin |
| Negative terminal | GND |
3. Interfacing the KY-001 Temperature sensor module using the EzloPi Web Flasher
Click Connect.
- In the Device Configuration, tab click on One Wire.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we will set it to DS18B20.
- Set Out GPIO to 4.
- Set Device Subtype to DS18B20 Sensor.
- Then Click Apply Button.
4. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device. As we can see above, the temperature sensor module tile is showing the current temperature value.
5. MiOS Web Application
