B179 Voltage Sensor
This project aims to enable homeowners to monitor and manage their electrical system voltage levels with the help of a B179 voltage sensor and the EzloPi device. By integrating the B179 voltage sensor into the EzloPi ecosystem, users will have the ability to track voltage variations and create automated responses to maintain the health and safety of their electrical systems.
From ESP32 (30 pins) to the voltage sensor:
  • B179 Voltage Sensor Module (0 to 25V DC)
  • Connect the GND from the ESP32 to the GND of the voltage sensor.
  • Connect the D33 pin from the ESP32 to the pin ‘S’ of the voltage sensor.
  • No need to connect the ‘+’ pin of the voltage sensor to the ESP32.
3. Interfacing the B179 voltage sensor using EzloPi Web Flasher
  1. credentials that you just set earlier while signing up
  1. Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
  2. In the Device Configuration, tab click on Analog Input..
  1. An Analog Input window will open for inputting the following parameters:
  • Set a Device Name of your choosing. In our case, we set it to Voltmeter.
  • Set Device Subtype to Shunt voltmeter.
  • Set the IN GPIO to 33.
  • Set the Resolution to 10 bits.
  • Now Click the Apply button.
  • After clicking the apply button you can see a table of your settings in device configuration tab.
4. MiOS App
Google PlayApple App Store
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. In the above figure, the voltmeter/voltage sensor tile displays the voltages being measured by the sensor.
5. MiOS Web Application
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. In the above figure, the voltmeter/voltage sensor tile displays the voltages being measured by the sensor.
Buy Components
