Automated LED lamp control using LDR digital sensor
This project aims to improve lighting efficiency using a digital LDR (Light Dependent Resistor) sensor integrated with the EzloPi device. The digital LDR sensor will detect ambient light levels, allowing for automatic state control of the LED lamp for applications where lighting automation is required such as street lights or smart homes depending on the environment light intensity. Through EzloPi, this project enables remote monitoring and control of the LED lamps.
This offers significant energy savings by optimizing light output based on real-time environmental conditions, reducing unnecessary energy consumption. Additionally, it enhances safety by ensuring adequate illumination levels during low-light conditions. Overall, the integration of digital LDR sensors with EzloPi presents a cost-effective and sustainable solution for efficient lighting management.
Welcome to the project demonstration video section. The following video showcases the key aspects of Automated LED lamp control using LDR digital sensor, providing a visual walkthrough of its implementation.
- LM393 based 4-pin photoresistor sensor module.
- XY-MOS, high-power dual MOSFET driver module.
- 24 LEDs mini lamp.
From ESP32 to LDR Module:
| ESP32 | LDR Module |
| 3V3 | VCC |
| GND | GND |
| D4 | D0 |
From ESP32 to the MOSFET driver module:
| ESP32 | MOSFET driver |
| D5 | Trig |
| VIN | VIN+ |
| GND | GND, VIN- |
From MOSFET driver module to 24 LEDs mini lamp:
| MOSFET driver | 24 LEDs Strip |
| OUT+ | 5V |
| OUT- | GND |
4. Interfacing the LDR sensor module with LED using EzloPi Web Flasher
1. Set up your device/hardware by visiting https://config.ezlopi.com/
Click Connect
- Set a device name of your choosing. In our case, we set it to LDR.
- Set Device subtype to LDR Sensor (Digital).
- Set OUT GPIO to 4.
- Set the default value to LOW.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Output.
- Set a device name of your choosing. In our case, we set it to LED.
- Set Device subtype to LED.
- Set OUT GPIO to 5.
5. MiOS Web Dashboard
- Now, on the MiOS web dashboard, you will be able to see the tile for the LED. The tile will indicate the status of the LED depending on the light being detected by the LDR sensor.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Automation MeshBot click on Local.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as LDR with LED.
- Set Node Type to Device.
- Set the Node to LDR.
- Set the Capability to Switch.
- Set the value to True.
- Set these values in the True part of the ACTION section.
- Set the Controllable to LED.
- Set the Capability to switch.
- Set the Value to true.
- Set these values in the False part of the ACTION section.
- Set the Value to false.
- Now Click the Save button.
- Here in the MiOS web dashboard, you can see that when the LDR sensor gets very little or no light. The LED lamp turns on because of the rules we have set in meshbot.
6. MiOS App
- Now, on the MiOS mobile dashboard, you will be able to see the tile for the LED. The tile will indicate the status of the LED depending on the light being detected by the LDR sensor.
- Here, as seen on the MiOS mobile dashboard, when the LDR Sensor gets very little or no light, the LED lights up because of the rules we have set in meshbot.
