Monitor your aquarium at all times
Automated aquarium management system
The smart aquarium management system project leverages the EzloPi device to monitor water levels using a P45 float switch. When the water level drops below a set threshold, the float switch triggers an LED indicator to alert the users. This simple, yet effective system ensures timely intervention for maintaining the correct water level, enhancing the safety and health of aquatic life in the aquarium. The project can be expanded to integrate additional sensors and controls, providing automated solutions for water refilling and other aquarium management tasks.
Welcome to the project demonstration video section. The following video showcases the key aspects of Automated aquarium management system, providing a visual walkthrough of its implementation.
- P45 float switch.
- LED with 100 Ohm Resistor.
From ESP32 to the Float Switch:
| ESP32 | Float Switch |
| GND | 1st Terminal |
| D4 | 2nd Terminal |
From ESP32 to the LED:
| ESP32 | LED | Resistor |
| D13 | - | Terminal no.1 |
| GND | Cathode | - |
| - | Anode | Terminal no.2 |
4. Interfacing the Float Switch and LED using the EzloPi Web Flasher
Click Connect
- A window will be opened for inputting the following parameters:
- Set a Device Name of your choosing. In our case, we will set it to Float Switch.
- Set INPUT GPIO to 15.
- Set the Device Subtype to Float Switch.
- Set the Resistor to PULL DOWN.
- Then Click Apply Button.
- Set a Device Name of your choosing. In our case, we will set it to LED.
- Set the Device Subtype to LED.
- Set OUT GPIO to 13.
5. MiOS Web Dashboard
- Now, on the MiOS web dashboard, you will see the tiles of your connected devices as shown above labeled as Float switch and LED. Currently, the float switch tile shows “water_level_ok message” while LED shows OFF status.
MeshBots:
- After clicking on Create new MeshBot, you will see this now under Automation MeshBot click on EzloPi.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test002.
- Set Node Type to Device.
- Set the Node to Float Switch.
- Set the Capability to Water level alarm.
- Set the Armed State to any.
- Set the value to water_level_above_high_threshold.
- Set Node type to Device.
- Set Controllable to LED.
- Set Capability to switch.
- Set Value to true.
- Set Value to false.
- Now in the above picture, It shows that when water level goes below our required limit in the aquarium then the LED will turn ON. We can also use a motor instead of the LED so that when water level decreases then the motor pumps the water into the aquarium tank according to rules we have set in the meshbot.
6. MiOS App
- Now, on the MiOS mobile dashboard, you will see the tiles of your connected devices as shown above labeled as Float switch and LED. Currently, the float switch tile shows “water_level_ok message” while LED shows OFF status.
- Now in the above pic, It shows that when water level goes below our required limit in the aquarium then the LED will turn ON. We can also use a motor instead of the LED so that when water level decreases then the motor pumps the water into the aquarium tank according to rules we have set in the meshbot.
