Innovate with EzloPi
Atmospheric and plant hydration monitoring
This project involves creating an atmospheric and plant hydration monitoring system using the EzloPi device. The HD-38 soil moisture sensor with an FC-28 probe tracks soil moisture levels, ensuring plants receive optimal hydration. Meanwhile, the BME280 sensor provides accurate atmospheric data, including temperature and humidity. Together, these sensors enable real-time monitoring of both environmental and soil conditions, making it ideal for smart gardening and agricultural applications. The setup offers a compact, IoT-enabled solution for comprehensive plant and atmospheric care.
Welcome to the project demonstration video section. The following video showcases the key aspects of Atmospheric and plant hydration monitoring, providing a visual walkthrough of its implementation.
- HD-38 soil moisture sensor with FC-28 probe.
- BME 280 temperature and humidity sensor.
From ESP32 to HD-38 Module:
ESP32 | HD-38 |
3V3 | VCC |
GND | GND |
D15 | DO |
D33 | AO |
From HD-38 to FC-28:
HD-38 | FC-28 |
POS | POS |
NEG | NEG |
From ESP32 to BME280:
ESP32 | BME280 |
3V3 | VCC |
GND | GND |
D21 | SDA |
D22 | SCL |
4. Interfacing the Soil Moisture Sensor & BME280 with EzloPi Web Flasher
Click Connect
- Set a Device name of your choosing. In our case we set it to Soil Moisture Sensor.
- Set the Device Subtype to Soil Moisture Sensor.
- Set the ADC input pin to 33.
- Set the Resolution to 10-bit
- Then Click Apply Button.
- An I2C window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to BME280.
- Set the Device subtype to BMP280 I2C.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark both the boxes of Enable pullup.
5. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- After opening the MiOS mobile app, we can see the soil moisture sensor tile and BME280 tiles which are for temperature and humidity. The tiles are showing the real-time data of soil hydration levels which helps us keep an eye on a plant's health while we can also monitor atmospheric data such as temperature and humidity which are also very important for plants growth.
6. MiOS Web Dashboard
