In this project demonstration, we will show you how to convert an existing project into a smart project using the ESP32 development board. The ESP-based EzloPi device provides the capabilities to convert your hardware (projects or devices/sensors) into IoT capable devices.
This following user guide will take you through the steps to make existing Arduino projects into smart projects using ESP MCU based boards. We can get an understanding for this easy process of converting existing or new projects into smart EzloPi projects.
Arduino Nano ESP32 combines the form factor and ease of use of the Arduino Nano with the processing power and wireless capabilities of the ESP32. This combination allows you to create projects that take advantage of the Arduino ecosystem and libraries while also incorporating Wi-Fi and Bluetooth connectivity for various IoT applications. We have demonstrated the Arduino Nano ESP32 as our EzloPi device by interfacing the ESP32 RGB LED Module.
The following components are required for interfacing the Arduino Nano ESP32 RGB LED module with the EzloPi device:
- Arduino Nano ESP32 as an EzloPi smart device.
- KY-009 RGB LED module.
The wiring diagram of Arduino Nano ESP32 is represented as follows:
From Arduino Nano ESP32 to the RGB LED module:
- Connect the GND from the ESP32 to the GND pin of the RGB LED module.
- Connect the D5 pin from the ESP32 to the RGB led module pin labeled with Red.
- Connect the D4 pin from the ESP32 to the RGB led module pin labeled with Green.
- Connect the D2 pin from the ESP32 to the RGB led module pin labeled with Blue.
3. Interfacing the Arduino Nano ESP32 RGB LED module with EzloPi Web Flasher
Click Connect.
- If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wifi SSID and Wifi Password.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Arduino Nano ESP32 RGB LED.
- Set Device Subtype to RGB LED.
- Set the GPIO1 pin to 2.
- Set the GPIO2 pin to 4.
- Set the GPIO3 pin to 5.
- Now Click the Apply button.
4. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- As you can see in the example given above, we can see the RGB LED tile. We can control the RGB module with the MiOS app to control the on/off state and also change the brightness and color of the LED.
- We can change the colors of the RGB LED by clicking on the circle present on the right hand side of the slider button.
- Here, it can be seen that we have successfully converted an Arduino project without any smart capabilities into a smart project by using an ESP-based development board.
5. MiOS Web Application
- On the MiOS web dashboard, the RGB LED tile can be seen, where the RGB LED on/off button is present and brightness/intensity can be varied by using the slider button along with the RGB color control button.
- From the MiOS web application, the colors of RGB LED can also be changed by clicking on the circle button present on the right hand side slider button.
