Smart appliance monitoring with EzloPi!
Appliance vibration and door monitoring system
This project aims to develop a robust and efficient light monitoring system using an LDR sensor for light monitoring. This smart monitoring system utilizes solar energy for charging the battery, which also powers the system during periods of low light availability or when solar energy is not available. The system incorporates an LDR (Light Dependent Resistor) analog sensor to detect ambient light levels and adjust its operation accordingly. This integration enables applications such as automated lighting control, energy efficiency optimization, or security systems based on environmental light conditions. Solar panel is also integrated in this project for EzloPi device to work independently without the aid of any external power supply.
With EzloPi smart devices, users can deploy these projects for security applications and smart home monitoring to provide a heightened level of control and awareness in your smart spaces.
Welcome to the project demonstration video section. The following video showcases the key aspects of Appliance vibration and door monitoring system, providing a visual walkthrough of its implementation.
- MC-38 Magnetic door switch.
- LM393 Vibration sensor module
From ESP32 to the MC-38 Magnetic door switch:
| ESP32 | MC-38 |
| D5 | 1st terminal |
| GND | 2nd terminal |
From ESP32 to the Vibration Sensor Module:
| ESP32 | Vibration Sensor |
| 3V3 | VCC |
| GND | GND |
| D4 | D0 |
4. Interfacing the Vibration sensor and magnetic door switch module using the EzloPi Web Flasher:
Click Connect
- Set a device name of your choosing. In our case, we set it to Vibration Sensor.
- Set the INPUT GPIO input pin to 4.
- Set device Subtype to Vibration Sensor.
- Now Click the Apply button.
- Again, In the Device Configuration, tab click on Digital Input.
- Set a device name of your choosing. In our case, we set it to Magnetic Door Sensor.
- Set the INPUT GPIO input pin to 5.
- Set device Subtype to Reed Switch.
- Then Click Apply Button.
5. MiOS Web Dashboard
- As you can see both Magnetic Door Sensor and Vibration Sensor tiles are visible with the messages “Open” and “No Motion” respectively.
MeshBots:
- After clicking on Create new MeshBot you will see new options, now under Notification MeshBot click on Create.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Vibration Update.
- Set these values in TRIGGER section:
- Set Node Type to Device.
- Set the Node to Vibration Sensor.
- Set the Capability to Motion.
- Set the Armed State to Armed.
- Set the value to True.
- Set Controllable Type to Notification.
- Set the User to Your user account .
- Set the Channels to email,push.
- Set the Subject to Vibration Update.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, Vibration is detected.
- Now, we create another meshbot for door alert.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Door Alert.
- Set the Node to Magnetic Door Sensor.
- Set the Capability to Dw state.
- Set the value to dw_is_opened.
- Set the Subject to Magnetic Door Update.
- Write the suitable Message body that you want to receive in your email. As you can see, we write, Door has been opened.
- As seen in the MiOS web dashboard above, the door sensor tile and vibration sensor tile are visible with the message “Closed” and “No Motion” respectively which indicates that the door sensor is detecting a magnetic field while the vibration sensor is not detecting any vibration.
- As we can see, we have received email through Meshbot when a any appliances door is open
6. MiOS App
- After opening the dashboard, you will be able to see the tile of your connected device.
- As seen in the MiOS mobile dashboard, the door sensor tile and vibration sensor tile are visible with the message “Closed” and “No Motion” respectively which indicates that the door sensor is detecting a magnetic field while the vibration sensor is not detecting any vibration.
- When the ESP32 does not detect any magnetic field or object, the tile will display the “Open” message and we will receive an email via meshbot, as shown in the MiOS mobile dashboard. Whereas the vibration sensor is displaying the “Motion” message which means that it is detecting vibration.
