Real time monitoring for a safe environment!
Android (section of varying length running) effect implementation by interfacing the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the “Android” effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of How to create an addressable LED with Android Effect and EzloPi, providing a visual walkthrough of its implementation.
From Power Supply to ESP32 and LED Strip:
Select EzloPi Addressable LED.
