Create a safe environment with EzloPi!
Alcohol detection alerts through EzloPi meshbot
The project aims to integrate an MQ3 alcohol sensor with the EzloPi device, utilizing its automation capabilities to create a robust alcohol detection system. The EzloPi automation meshbots will be employed to promptly alert the user when alcohol presence is detected in the surrounding atmosphere.
The MQ3 Alcohol sensor is a gas sensor widely used to detect the presence of alcohol vapor in the environment. It is particularly popular for applications involving alcohol detectors in automobiles, breath analyzers, and in various industrial safety systems. We can set up threshold values to trigger alerts or actions when alcohol concentration exceeds a certain limit. This could include sending notifications, activating alarms, or interfacing with other devices for safety measures and monitoring.
- MQ3 Alcohol sensor module.
The wiring diagram for the ESP32 30-pin is represented as below:
From ESP32 to the MQ3 Alcohol Sensor:
- Connect Vin from the ESP32 to the sensor's VCC.
- Connect the GND from the ESP32 to the GND pin of the sensor.
- Connect D33 from the ESP32 to the sensor's A0 pin.
3. Interfacing the MQ3 Alcohol sensor module with EzloPi Web Flasher:
- Log in using the credentials that you just set earlier while signing up.
Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
- A window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to MQ3.
- Set Device subtype to MQ3 Alcohol Sensor.
- Check the box of GPIO 1.
- Set GPIO 1 to 25.
- Check the box of GPIO 2.
- Set GPIO2 to 33.
- Then Click the Apply Button.
- After clicking the apply button you can see a table of your settings in the device configuration tab.
4. MiOS Web Application
- After opening the MiOS web dashboard, you see the tile of your connected device. The MQ3 Alcohol sensor tile will reflect the concentration readings of the alcohol vapors in the environment. As shown above, there is no gas being currently detected by the sensor.
Meshbots
- On the meshbot screen, click on the Create new MeshBot button present on the top right corner of the screen.
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen, you will see that we can create a name of our choosing, in this case, we write it as MQ3.
- In the trigger tab, you can set the TRIGGER for your device and in the ACTION tab you can set the action to be performed based on the trigger which you have created.
- Set these things in the TRIGGER section:
- Set Node Type to Device.
- Set the Node to MQ3.
- Set the Capability to parent_abstract.
- Set the variables to uuid.
- Set the Comparator to Greater (>).
- Set the value to 10 (It will trigger when the temperature is greater than 10).
- Set Controllable Type to Notification.
- Set the User to Your user account but in our case the user account is Tayyab..
- Set the Channels to email, push.
- Set the Subject to Alcohol Detection Alert.
- Set the Message body info to Alcohol is Detected.
- After clicking the apply button you can see a table of your setting in the Current Configuration tab.
- The MQ3 Alcohol sensor tile reflects the concentration readings of the alcohol vapors being detected by the sensor at that moment i.e. greater than 10, therefore an email is sent to the user to alert about the detected alcohol vapor levels.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The MQ3 Alcohol sensor tile reflects the concentration readings of the alcohol vapors being detected by the sensor at that moment.
