Be protected all the time with EzloPi
Air quality and UV exposure monitoring
The air quality and UV exposure monitoring system combines the MQ2 gas sensor and TSL2561 luminosity sensor with the EzloPi device. The MQ2 sensor detects levels of harmful gases like smoke, LPG, CO, and methane, providing real-time data on indoor or outdoor air quality. Meanwhile, the TSL2561 measures luminosity, including UV exposure levels, allowing for effective monitoring of sunlight intensity and potential UV risks. With EzloPi device’s smart capabilities, this system can alert users to hazardous air quality and excessive UV exposure, promoting healthier living environments.
Welcome to the project demonstration video section. The following video showcases the key aspects of Air quality and UV exposure monitoring, providing a visual walkthrough of its implementation.
- MQ2 gas sensor
- TSL2561 luminosity sensor.
- Two 1K Ohm resistors.
From ESP32 to the MQ2 Gas Sensor:
| ESP32 | MQ2 | Resistor 1 | Resistor 2 |
| VIN | VCC | - | - |
| GND | GND | - | - |
| D13 | D0 | - | - |
| - | A0 | Terminal 1 | - |
| D33 | - | Terminal 2 | Terminal 1 |
| GND | - | - | Terminal 2 |
From ESP32 to the TLS256 Luminosity sensor:
| ESP32 | TSL2561 |
| 3V3 | Vin |
| GND | GND |
| D21 | SDA |
| D22 | SCL |
4. Interfacing the Gas sensor & Luminosity sensor using the EzloPi Web Flasher:
Click Connect
- An Other window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to MQ2.
- Set Device subtype to MQ2 LPG Gas Sensor.
- Tick mark the boxes of GPIO 1 & GPIO2.
- Set the GPIO 1 to 13.
- Set the GPIO 2 to 33.
- Then Click Apply Button.
- An I2C window will be opened for inputting the following parameters:
- Set a Device name of your choosing. In our case, we set it to TSL2561.
- Set Device subtype to TLS256 Luminosity.
- Set Slave address to 41.
- Set SDA pin to GPIO21.
- Set SCL pin to GPIO22.
5. MiOS App
- Here, we can see the TSL2561 luminosity sensor and MQ2 gas sensor tiles in the MiOS mobile app above. The above figure indicates that very little amount of light is being detected by the sensor and the gas sensor also detects normal concentration of gas in the environment. From this system, we can monitor the environment around us and take action accordingly.
- Now, as we can see the light intensity has increased and so has the gas concentration.
6. MiOS Web Dashboard
- Here, we can see the TSL2561 luminosity sensor and MQ2 gas sensor tiles in the MiOS web dashboard above. The above figure indicates that very little amount of light is being detected by the sensor and the gas sensor also detects normal concentration of gas in the environment. From this system, we can monitor the environment around us and take action accordingly.
