Your Precision Weight Measurement Solution!
Advanced Weight Measurement using HX711 and load cell
In this project, we will interface the HX711 amplifier with the EzloPi device to easily read load cells to measure any given weight.
The HX711 amplifier is a precision analog-to-digital converter (ADC) designed specifically for weight and load cell applications. It is widely used in various industries for measuring and monitoring weight and force. We can integrate the load cell and HX711 module into our EzloPi projects, whether it’s for any home automation task, monitoring inventory, controlling a robotic arm, or any other purpose that requires weight measurement.
2. Circuit Diagram & Interface - HX711 Wiring
- HX711 Amplifier with Load Cell.
From ESP32 to HX711 Module:
- Connect 3V3 from the ESP32 to the VCC of the module.
- Connect the GND from the ESP32 to the GND pin of the module.
- Connect D4 from the ESP32 to the SCK pin of the module.
- Connect D16 from the ESP32 to the DT pin of the module.
From Load Cell to the HX711 Module:
- Connect the Red wire of the Load cell to the E+ pin of the module.
- Connect the Black wire of the Load cell to the E-pin of the module.
- Connect the White wire of the Load cell to the A-pin of the module.
- Connect the Green wire of the Load cell to the A+ pin of the module.
3. Interfacing the HX711 Load Cell using EzloPi Web Flasher
- Log in using the credentials that you just set earlier while signing up.
Now, select the COM Port to which your ESP32 device is connected. In our case, the COM3 port is used.
Click Connect.
- If you are new to this and it’s your first time configuring, select Create new Device ID. Enter Wifi SSID and Wifi Password.
- An Other window will open for inputting the following parameters:
- Set a device name of your choosing. In our case, we set it to Load Cell.
- Set Device subtype to HX711 Load Cell.
- Tick the GPIO 1 and set it to 18.
- Similarly, Tick the GPIO 2 and set it to 19.
- Leave the GPIO 3 unchecked.
- Now Click the Apply button.
- After clicking the apply button you can see a table of your settings in the device configuration tab.
4. MiOS App
- After some time, a popup will appear saying Device Flashed Successfully! ! This means that your device has been set up successfully.
4. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. The load cell tile will reflect the weight being applied to it at that instance.
5. MiOS Web Application
- The load cell tile will reflect the weight or the force being applied to it at that instance on the MiOS web dashboard.
