Smart projects to make life easier
Advanced motion detection system
The advanced motion detection system integrates the MPU6050 3-axis accelerometer and gyroscope module and a PIR motion sensor to enhance motion sensing capabilities. The MPU6050 detects movement patterns, orientation, and acceleration, making it ideal for fine motion tracking. Complementing this, the PIR sensor identifies motion through heat signatures, enabling detection of human presence. When interfaced with the EzloPi device, the system combines to provide comprehensive motion detection, triggering automated responses such as activating alarms, lights, or cameras. This system is suited for applications like smart home security, robotics, and interactive environments.
- MPU6050 3-axis accelerometer and gyroscope module.
- PIR motion sensor.
From ESP32 to the MPU6050:
| ESP32 | MPU6050 |
| 3V3 | VCC |
| GND | GND |
| D21 | SDA |
| D22 | SCL |
From ESP32 to the PIR sensor:
| ESP32 | PIR Sensor |
| VIN | VDD |
| GND | GND |
| D13 | SIG |
4. Interfacing the MPU6050 3-Axis Accelerometer & Gyroscope with PIR Sensor with the EzloPi Web Flasher:
Click Connect
- f you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- An I2C window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to MPU6050.
- Set the Device Subtype to MPU6050 Accelerometer and Gyroscope.
- Set the Slave Address to 104.
- Set the SDA pin to 21.
- Set the SCL pin to 22.
- Tick mark the Button Enable Box.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Digital Input
- A Digital Input window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to PIR Sensor.
- Set the INPUT GPIO to 13.
- Set the Device Subtype to PIR Sensor.
- Set the Resistor to PULL DOWN
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. The MPU6050 shows the accelerometer and gyro data of the three axes i.e X,Y and Z of the entrance we are monitoring whereas the PIR sensor indicates the presence of any person or object.
- Now as seen above, there are now different values being shown on the tiles of MPU6050 regarding to our focal area so when there is a certain value on the Y-axis of the sensor and also when the PIR gets a trigger signal then it is obvious that some movement is happening.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. The MPU6050 shows the accelerometer and gyro data of the three axes i.e X,Y and Z of the entrance we are monitoring whereas the PIR sensor indicates the presence of any person or object.
