Addressable LED speed control of effect
In this project, we have increased the speed of the ‘Android’ effect implemented on the addressable LED with the EzloPi device.
Various effects can be set up using the addressable LED strip and EzloPi device as we have demonstrated the increase in speed of the ‘Android’ effect in this project.
Welcome to the project demonstration video section. The following video showcases the key aspects of Addressable LED speed control of effect, providing a visual walkthrough of its implementation.
- Jumper wires
Note:
Addressable LED strip | ESP32 |
LED Data (Din) | RX2 (GPIO16) |
4. Interfacing the Addressable LED strip using EzloPi Web Flasher:
5. MiOS Web Dashboard
- On the top right side of the screen under Segment 0, you can set the number of LEDs you want to use for specific effect. In our case, we have set it to 10.
- Under Effect mode, click on Android to apply this effect. By following the above steps, we can successfully implement an Android Effect using addressable LEDs and the EzloPi smart device, enhancing the visual appeal and versatility of our IoT lighting setup.
- On the bottom mid section of the screen, you will see the clock icon. Here, we can adjust the speed of our desired effect as we have demonstrated the speed increase on the ‘Android’ effect.
