ACS712 Current Sensor
1. About this example - ACS712 ESP32
The project demonstrates how to integrate the ACS712 current sensor with the EzloPi device, offering a powerful solution for real-time current monitoring and control in various applications. By combining the accuracy of the ACS712 sensor with the versatility of the EzloPi platform, this project enables users to monitor and efficiently manage their electrical systems.
  • ACS712 current sensor module.
  • Two resistors of 1K ohm and 2K ohm.
From ESP32 (30 pins) to the ACS712 module:
  • Connect the GND from the ESP32 to the GND pin of the ACS712 current sensor module.
  • Connect the D33 pin from the ESP32 to the OUT pin of the ACS712 current sensor module through the voltage divider.
  • Connect the Vin pin from the ESP32 to the VCC pin of the ACS712 current sensor module.
3. Interfacing the ACS712 current sensor using EzloPi Web Flasher
  1. Log in using the credentials that you just set earlier while signing up.
Click Connect.
  2. In the Device Configuration, tab click on Analog Input..
  1. An Analog Input window will open for inputting the following parameters:
  • Set a Device Name of your choosing. In our case, we set it to Current Sensor.
  • Set Device Subtype to CS718TELC 05B Current Sensor.
  • Set the ADC input pin to 33.
  • Set the Resolution to 10-bit.
  • Now Click the Apply button.
  • After clicking the apply button you can see a table of your settings in the device configuration tab.
4. MiOS App
Google PlayApple App Store
  1. After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. In the above figure, the current sensor tile displays the current values being measured by the sensor of the connected AC load.
5. MiOS Web Application
  1. After opening the MiOS web dashboard, you will be able to see the tile of your connected device. In the above figure, the current sensor tile displays the current values being measured by the sensor of the connected AC load.
Buy Components
