AC Lamp Setup with Relay
This project aims to create a simple and effective system for remotely controlling an AC lamp using a relay through the EzIoPi device. The EzloPi is a versatile and user-friendly IoT platform that allows users to interface with various sensors and actuators, making it an ideal platform for home automation and IoT projects.
In this project, we will leverage the capabilities of the EzIoPi device to control the state of an AC lamp, turning it on and off remotely through the MiOS Application.
The following components are required for interfacing the lamp using the EzloPi device:
- A 5V single-channel relay module for controlling the circuit.
- A momentary switch with pull-up resistor of value 10KOhms.
- AC lamp and holder with wires to connect to AC mains.
The following connections are made in order to complete the entire circuit setup:
From ESP32 to Relay:
- Connect Vin to the Vcc of the relay module.
- Connect the GND of the ESP32 to the GND of the relay module.
- Connect D5 to the signal pin on the relay module.
ESP32 to Push Button:
- Connect the D15 pin through a pull-up resistor of value 10k to the push button leg A.
- Connect GND to the push button leg B.
From Relay to AC load:
- Connect the Normally Open (NO) pin to the AC phase wire.
- Connect the Common (COM) pin to Neutral Wire.
4. Interfacing the AC lamp with relay setup using EzloPi Web Flasher
Click Connect.
- In the Device Configuration, tab click on Digital Output..
- A digital output window will open for inputting the following parameters:
- Set a device name of your choosing. In our case we set it to Relay.
- Set Out GPIO to 2.
- Set Resistor to PULL UP.
- Set the default value to low.
- Check the Button Enable option.
- Set INP GPIO to 5.
- Now Click the Apply button.
5. MiOS App
- After opening the MiOS mobile dashboard, you will be able to see the tile of your connected device. In the above figure, the status of the device is indicated whether it is ON or OFF. Also, clicking on the device tile will toggle the state of the device.
- The bulb is turned ON by clicking on the relay button and its status has changed as shown in the above picture.
6. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. In the above figure, the status of the device is indicated whether it is ON or OFF. Also, clicking on the device tile will toggle the state of the device.
- As seen above on the dashboard, the bulb is turned OFF.
