Smart protection with EzloPi
360° Obstacle detection using ultrasonic sensors
The following project utilizes four HC-SR04 ultrasonic sensors strategically placed to cover all directions, ensuring full obstacle detection around the system. Each sensor calculates the distance to nearby objects using ultrasonic waves and relays the data to the EzloPi device for processing. The EzloPi device continuously monitors the readings and identifies obstacles within its range. By integrating data from all four sensors, the system provides real-time, reliable obstacle detection across 360 degrees. This setup is ideal for applications such as home security, robotics, automation, and collision avoidance systems, offering accurate and efficient spatial awareness. The project is easy to implement, leveraging the versatile capabilities of the EzloPi device for seamless sensor integration and obstacle feedback.
- 4 x HC-SR04 Ultrasonic distance sensor.
From ESP32 to the HC-SR04 - 1:
| ESP32 | HC-SR04 |
| VIN | VCC |
| GND | GND |
| D13 | ECHO |
| D15 | TRIG |
From ESP32 to the HC-SR04 - 2:
| ESP32 | HC-SR04 |
| VIN | VCC |
| GND | GND |
| D4 | ECHO |
| D5 | TRIG |
From ESP32 to the HC-SR04 - 3:
| ESP32 | HC-SR04 |
| VIN | VCC |
| GND | GND |
| D18 | ECHO |
| D32 | TRIG |
From ESP32 to the HC-SR04 - 4:
| ESP32 | HC-SR04 |
| VIN | VCC |
| GND | GND |
| D25 | ECHO |
| D33 | TRIG |
4. Interfacing the Ultrasonic sensors using the EzloPi Web Flasher:
Click Connect
- f you are new to this and it's your first time configuring, select Create new Device ID. Click on the Configure Wifi button. Enter Wifi SSID and Wifi Password.
- An Other window will be opened for inputting the following parameters:
- Set the Device name of your choosing. In our case, we set it to Ultrasonic Sensor 1.
- Set the Device Subtype to Ultrasonic Sensor HC SR04.
- Tick mark both boxes of GPIO1 & GPIO2.
- Set the GPIO1 pin to 13.
- Set the GPIO2 pin to 15.
- Then Click Apply Button.
- Again, In the Device Configuration, tab click on Other
- Set the Device name of your choosing. In our case, we set it to Ultrasonic Sensor 2.
- Set the GPIO1 pin to 4.
- Set the GPIO2 pin to 5.
- Set the Device name of your choosing. In our case, we set it to Ultrasonic Sensor 3.
- Set the GPIO1 pin to 18.
- Set the GPIO2 pin to 32.
- Set the GPIO1 pin to 25.
- Set the GPIO2 pin to 33.
5. MiOS App
- After opening the MIOS mobile app, you will be able to see the tiles of your connected devices. Four ultrasonic sensors are used here to measure distance from all sides making it 360 object detection. The sensor outputs are shown here, by these outputs we can take any action through our meshbot automation feature.
6. MiOS Web Dashboard
- After opening the MIOS web dashboard, you will be able to see the tiles of your connected devices. Four ultrasonic sensors are used here to measure distance from all sides making it 360 object detection. The sensor outputs are shown here, by these outputs we can take any action through our meshbot automation feature.
