In this project, we will interface an AC lamp with the EzloPi device using a single channel relay module which will perform as a switch. This project will enable users to remotely control the AC lamp at any time using the MiOS smart application. Additionally, by utilizing the EzloPi MeshBots, we can schedule the lamp according to our requirements. For instance, we can schedule the lamp to turn on at night and turn off in the morning automatically. This project is designed to provide a user-friendly and convenient solution for automating and managing lighting in a smart home environment and to enhance the user experience and increase energy efficiency.
- Single channel 5V Relay module.
- AC Lamp
The wiring diagram for ESP32 is represented as below:
From ESP32 to the Relay module:
- Connect the D2 pin from the ESP32 to the Signal pin of the relay module.
- Connect the GND from the ESP32 to the GND of the relay module.
- Connect the ‘VCC’ terminal to 3V3 on the ESP32.
From Relay module to 220V AC Lamp:
- Connect the common of the relay module to the neutral.
- Connect the normally open point to the NO terminal of the bulb, the second point of the bulb will be connected to the phase voltage.
3. Interfacing the Relay module using the EzloPi Web Flasher
Click Connect.
- In the Device Configuration, tab click on Digital .
- Set device name to Relay.
- Set Device subtype to Relay.
- Set OUT GPIO to 2.
- Set Resistor to PULL UP.
- Set the default value to LOW.
- Now Click the Apply button.
4. MiOS Web Application
- After opening the MiOS web dashboard, you will be able to see the tile of your connected device. The state of the AC lamp can be controlled by just touching on the tile for the lamp connected to the relay module.
- Currently the tile for the relay is OFF, which indicates that the AC lamp is OFF and will turn on according to the MeshBot rules which we will configure below.
MeshBots:
- After clicking on Create new MeshBot you will see this now under Automation MeshBot click on Cloud.
- On the next screen you will see that we can create a name of our choosing, in this case we write it as Test006.
- Set these values in TRIGGER section:
- Set Node Type to Date and Time.
- Set the Node to Days of the Week and select the days.
- Set the Choose the moment of day activation will occur.
- Click on TRUE.
- Set Node Type to Device.
- Set Controllable Type to Relay.
- Set the Capability Type to switch.
- Set the Value to true.
- Set Action to immediately.
- Now Click the Save button.
- Here in the MiOS web dashboard, you can see that when the set time is reached, the relay turns on because of the meshbot rules.
5. MiOS App
- After opening the MiOS mobile app dashboard, you will be able to see the tile of your connected device. The state of the AC lamp can be controlled by just touching on the tile for the lamp connected to the relay module.
- Currently the tile for the relay is OFF, which indicates that the AC lamp is OFF.
- Similarly, it can be seen that when the set time is reached, the relay module is ON indicating that the AC lamp is also on. This indicates that the rules we have set in meshbot are working.
